#271
I meant the nice geometric aspect of the tartan.
Right, tea-break is over.....get back to work! |
#272
Which tartan is Ford Blue? |
#273
The icy cold one
#274
Hmmm maybe we need a MechMate coat of arms also
#275
lol, I knew I would start something
#276
Sean, the contactor that you are using for your dust collection and router is that a 25amp feeding both? I was thinking of doing something similar with the contactor feeding an electrical outlet mounted to the outside of the case and have the router and dust collector plugged in to it as the dust collector will not be dedicated to the MM and will used elsewhere when the MM is not in use. I was looking at the contactor cn-25r-f6 at factorymation.
#277
Craig
I am feeding my box 25a/220, thus I have easily 20amp/120v "available" for each switched circuit. The dust collector and router both have secondary breakers post contactor to limit consumption beyond rating in case of failure or surge/short. I am using a cn25 contactor. Thus,i am switching 2 hots and 1 nuetral. Did that help? If for some reason I need to just use a "dry contact", I have made allowances to easily change the contactor from "feeding" to truly just switching. |
#278
yes I see the mains feeding to both sides through the disconnect then one side going to each contactor, but is the contactor to the left that you are using for the router/d.c. wired into the E-stop on the schematic it looks like only the one on the right is wired to the E-stop loop.
#279
the contactor on the left is fed from the relay on the pmdx. Thus the estop condition on it is controlled by the pmdx but run thru the main estop contactor. This way, electrically either system will cause an estop for any reason the bob logic fails during a estop(my hand is in themachine) type of condition. I added this little extra routing. I added an extra set of contacts to the main estop contactor after photos were posted. It really is just a series connection thru a NO contact. Does this answer or explain what you are looking for?
#280
I think so, I just ordered a bunch of stuff from McMaster,Factorymation,automationdirect so in about a week I will probably have a bunch more questions
Thanks. |
#281
News Flash.
New product I have NEVER cut on the table before just arrived. I ordered 20 sheets...we will see how it does. I even ordered fancy schmancy bits to cut all of it. The product. 3/4" cabinet grade birch laminated 1 or 2 sides with various types of High pressure plastic laminate. This way, my cabinets are prefinished on all of the interior surfaces. Tonight should be fun ![]() |
#282
"Compression" schmancy bits?
#283
You betcha! Compression spiral 1/4" 7/8 CL, 2.25 OAL
I also order solid carbide, straight cut, 2 flute *onsrud* plastic cutting bits as well. Just in case. It's all about the testing ![]() |
#284
Gerald.
Those fancy schmancy compression bits and 20 sheets of laminated core plywood are NO match for the MechMate. I flew through 20 sheets in 4 hours this morning. Stats: 1/4" compression spiral and 1/4" carbide, 2 flute straight cut bits. - both performed equally well. - better cut edge with 2 flute - better chips with compression. - avg speed 180ipm with 2 passes .30 inch/pass I will be cutting 3/8" polycarbonate, 1/4" acrylic tomorrow ( well, in about 5 hours ![]() |
#285
Surely the compression cutter only works for one full depth pass? From what I read of the regular compression cutter users, they rarely cut material thicknesses more than 2X cutter diameters thick. ie. a 3/8" cutter for 3/4" material.
#286
Sean,
Can you give me the trade name for that laminate covered birch core ply? I would like to see if I can get that locally here in Cleveland. Thx! |
#287
I buy from Quality Plywood Specialties. It doesn't have a trade name.
Essentially, this is an in-house product that they do for customers. All they are doing is "laying up" cabinet liner (VT grade plastic laminate) on a sandiply core. 1 side or 2 side. In a very large press and roller machine for a very uniform glue up. Something I don't have inhouse. They just are set up for it and reduce my labor on each piece by about 2 hours per sheet. Thus a HUGE savings. Call your local ply supplier and see if they have this service. If not, you can buy versions of the material "preglued" from TCH hardware in Buffalo. Sean |
#288
Working hard for the money - and earning her keep
Okay,
The forum's been a little stale with pictures the past couple of weeks. So, I thought I would cheer up Gerald with some "dusty" photos! ![]() working hard for the money2.jpg working hard for the money.jpg |
#289
Beeeyooootiiiiifuuuullll
#290
Hey....2 brownie points for anyone that can name the 10 parts being cut on the left side of the bottom photo.
#291
OOOh OOh OOh I Know! I Know!
#292
push sticks?
#293
Leko and JR win the prize. Push sticks for the boys in the shop!
For your reward, please go to the head of the class and please hand sand all the edges of the parts coming off the table. ![]() |
#294
You sure are a proud owner of a MECHMATE beast. Nice post .
#295
See sean, now all you need is a vacuum table, line bore head and you will be set.
#296
Vacuum table parts all sitting in the corner with the dust collection. I just have to have a slow week so I can get it all moved to the other building.
Line bore head....most likely I will add a pneumatic drill motor for pointing. Thanks for reminding me about all the things I have to finish! |
#297
Sean, looks great what is your main business?
#298
Andy of the the Green Mountains.
Theater, Museums and Themed stuff...and a little General Contracting thrown in for good measure. The GC part lets me follow the rules and get permitting with ease. Burlington...I love that MicroBrew place in town across from campus where you can buy 80 beers and take a trip "around the world in 80 brews".....New Albans was a normal stop for me years ago. |
#299
Sean,
If you meanthe vermont brew pup across from the old Ben and Jerrys original garage which is now a parkinglot. Yeah the beer is good . My brother built the bar and his buddy welded up the old milk tanks that are now the brewery. The new Albans of which you speak must be St Albans ? Life is good up here except winter feels like it won't end. Will you be lasering any parts in the near future? |
#300
Yes, Lasering parts in the VERY near future. Hopefully next week.
But I will say, the Alabama connection is a great price! I can't beat it. I am closer to 400 (estimated) for all done here in orlando plus shipping. My laser/fabricator has had some challenges getting the new Mitsubishi laser to work consistently lately. Thus, I have been in a delay until they felt comfortable to run parts as an outsource and not for internal use only. |
| The second MM was easy, but the building's electrics were noisy #28 - Orlando, FL | smreish | MechMates already cutting | 58 | Sat 26 September 2020 17:36 |
| Corner finder | Rad Racer | General - MM Operating | 2 | Tue 28 May 2013 10:19 |
| Problems working the end of some Ballscrews | coinhunter | Miscellaneous / General / Whatever / Catchall | 5 | Thu 21 July 2011 14:06 |
| Working Out The Table Plan | dakmonf | Introduce yourself and start planning | 32 | Wed 30 June 2010 11:59 |
| Corner finder and cam clamps | Rad Racer | The Show Room | 9 | Sun 19 April 2009 09:06 |
