#331
Some craters I machined.
Tycho (Moon) and Gale(Mars) I doubled the Z depth with Tycho to get a better effect. Gale' I left the depth unaltered. The possibilities are infinite. STL files available here, http://nasa3d.arc.nasa.gov/models |
#332
Those are really cool
but I never would have thought someone would cut something like that. Who knew? The possibilities are 'out of this world', ha ha! |
#333
I finally got to make a reduction drive for the Z axis.
Ratio 3.273 : 1 The profile shop cut the plates -2mm on the outside and +2mm on the inside. The machine shop bored all the holes tight and tapped M4 for the grub screws instead of M6. It took longer than I thought it would to tune the motor. I will have to wait until next weekend to see if it works in the real world. |
#334
Sometimes I wish that I had a bigger machine
![]() I have 3 plain panel doors that have always annoyed me. The wife is away so I decided to play. The reduction drive for the Z axis is working well. It took a lot of tuning to find the correct settings for speed and velocity. It did not want to go slow. Onwards. |
#335
You have some very nice ideas Al.
#336
Well done....sure the wife will enjoy
#337
Wife is not going to find her house!
#338
Beautiful work.
#339
Al is going for bonus points! Nice work Sir!
#340
Spot on! Nice use of the machine.
#341
Year 2 report
It is now 2 years since the beast first stirred.
I thought that I had lost the photos of my build but I found them on my backup computer. A trip down Memory Lane this morning. They are now backed up on Google Drive. The last year has seen an energy chain fitted on the X axis. Working well. A 4th axis built, not used much but it is available. A Z axis reduction drive built. It is working well after some tuning problems. A lathe built. It works well. The door panel carving is ongoing. Something to do as I have 3 weeks off soon. Just wish some of my nice ideas would translate into some nice cash. A busy year with its ups and downs. Year 3 begins. I wonder what it will bring. Good to see that some new builds have started. |
#342
Glad to hear all is well Al.
You are an inspiration to those new builds. |
#343
2ys.....time do fly !!
Congrats on all your efforts and inspiring determination ! ![]() |
#344
I got fed up of carving door panels. 30 designs, 60 + programs.
Problems, panels different sizes, not square, tapered, mounted out of square, Different quality of wood, different types of wood, loose in frame, 2 1/2 kg of sawdust per side. All good fun. Took a break and did some pelmets instead. I forgot to mention in my last post that I put the electronics box on the wall. Much cleaner and easier to get at. I can get down but sometimes it is a struggle to get up again. |
#345
I hear you on the electrical enclosure. I did something similar and moved the enclosure onto 8020 framework and secured to the wall. Much nicer on the knees.
#346
I got a couple of new cutters off E bay.
I made some holders from some broken cutter shanks. The tapered ball nose was 6mm dia. The engraving bits were 1/8" dia. Both cut well. A couple of rubber band guns. The pump action is work in progress. |
#347
Wow nice intricate work, I bet your wife appreciates the MM as much as you do
#348
Kool work.
#349
Hot to damn hot here today.
40C, 104F. Machine working well, operator wilting. |
#350
Hope the operator partook in some alcoholic refreshments
![]() Know what you mean Al, we had our hottest April day EVER Wednesday, 38C, when it supposed to Autumn. Stayed out of my garage altogether and hid in the air con. |
#351
You guys stay cool on these hot days if you can.
#352
Up a notch, 41c today.
Possible 42c by the weekend. Lemon tea with ice during working hours. ![]() Beer with ice after 5pm. ![]() |
#353
Ouch Al! That is some serious heat. As Pete says, stay hydrated my friend, hope you can sleep nights.
#354
I got some offcuts from a local furniture maker.
Padauk mostly. There was some waney edged pieces. The wife said they would be good for house signs and that I should make a sample. I thought there is a house in New Orleans. Just the way my mind works. Not sure she understood. ![]() |
#355
Kool.
#356
Nice work my friend.
#357
Another shining example of a job with no money in it.
A shelf for a statue of the Buddha to sit on, requested by a friend of my wife. Padauk wood. Top 500 x 400mm The dolls are double sided machined and 31mm thick. Delivery tomorrow. Payment debatable/doubtful ![]() |
#358
I've cut plenty of similar projects Al.
While a thank you is nice, a real payment is better. |
#359
Variations on a theme of Naga
I made these over the last couple of weekends.
The Naga is a mythical water serpent. Mind you, they have pulled some strange things out of the Mekong river over the years. ![]() |
#360
Wow, they are so cool! Very nice job Al.
Wouldn't surprise me what is in some of the worlds rivers, I bet there are alot of scary things ![]() |
| Started making windows with the mechmate ... #70 - Rome, Italy | silverdog | MechMates already cutting | 100 | Wed 26 April 2017 23:02 |
| Lookin for Gremlins - Isarn, TH | lonestaral | Troubleshooting | 8 | Mon 02 November 2015 13:10 |
| Oh Can I ?? - Phuket Thailand | jek | Introduce yourself and start planning | 10 | Fri 24 June 2011 06:55 |
| Newbie to CNC - Chiangmai Thailand | chainarin2553 | Introduce yourself and start planning | 1 | Wed 15 June 2011 06:27 |
| Free Cad and Cam HeekCNC Windows & Linux | Regnar | CAM | 0 | Thu 16 September 2010 20:24 |
