Old Sat 14 November 2015, 11:09
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello all,
I'd like to cut my own gearboxes and I've been looking, preferably 4:1. my gantry is very heavy, 1/4" wall tubes. the only confirmed boxes that fit the 72 tooth pulley that i could find are rischoof, chopper & mikes.
does JR's box fit a 4:1? I like the size and simplicity of it, I would only add a belt tension to it.
I also just realized that torque is effected at higher rpm that is needed to run the machine at non-monotonous speeds. should I be concerned with this using the pk299-F4.5A?
Where are you guys finding the kevlar XL belts? other then mcmaster @ $24 a pop for a 90 tooth 3/8"
Pete, could you please tell me where you got those spindle mounts from? I likey.
Once I get this beast back together I'll hopefully be re-motivated to finish up the dreaded control box. A lot of holes and soldering to do.
Thanks All.
Old Sat 14 November 2015, 12:46
Stock drive products also carries belts that is another site to look at. I have a 4:1 reduction assembly that uses idlers and tensioners. It is for the Z but with some quick CAD changes you could make one to mount to the x, b and y. The spindle mount I made, if you would like to print let me know.
Old Sun 15 November 2015, 01:59
Father-of-Ash
Just call me: Bilal
Toledo, OH
Pete, I would love to have a look your boxes and spindle mounts.
I did check SDP/SI but they don't have kevlar in that config, abut then again I don't even know which boxes I'm going with yet so... (they do have it in 88 tooth)
I just had a look at your Z box and remembered it.
can you tell me how you calculated belt length with those additional idlers?
will a 20 tooth spur gear with 4:1 reduction become too a slow machine for the typical cnc'er? better with 25 or 30 tooth?
Old Sun 15 November 2015, 06:04
Bilal, here are the parts from SDP/SI that I suggest if you are using a half inch shaft,
A 6A 3-72NF03716 (72 tooth)
A 6A 3-18H3716 (18 tooth)
if your stepper shaft is 14mm like mine you'd have to machine the small pulleys. I have mine set up as 3.6:1 with a 20t pulley and kevlar belts but am looking to change it real soon. I do have belt reduction plates that someone was kind enough to share that work great. I'll have to dig up the files and get to you.
Old Sun 15 November 2015, 09:55
Father-of-Ash
Just call me: Bilal
Toledo, OH
Tom that would be much appreciated.
I also wanted to mention that B&B manufacturing is cheaper then sd/si, and Automation Direct is even cheaper then B&B. free shipping if over 50$, but they don't have kevlar belts.
I've used them a couple times so far.
Finally started assembling the machine last night, I'll put up some pics later today.
Old Sun 15 November 2015, 11:11
I have 3 different models of steppers and the 296 and 299 are 2 of those, I have found no problems so far. My rapids are 500 IPM because my ratios are lower so my steppers are turning fast. As far as the torque, properly sizing the power supply will help with that but torque/speed with always be an issue.
Old Sun 15 November 2015, 12:04
You can find the files I started with on Ross #74's (SURFCNC) Post#870. I think I modified them for my bearings, there is one of the support post (stand-off) holes that are real close so you may want to make modifications in that area. You can find a pic of the finished plates I cut with direct drive on my thread as well.
Old Sun 15 November 2015, 20:56
Father-of-Ash
Just call me: Bilal
Toledo, OH
Pete, thanks for the dxf.
Tom, I will take a look at Ross's as well.
Than you both for the info.
Here is a pic from today.
Old Sun 15 November 2015, 23:04
Looking great!
Old Mon 16 November 2015, 05:59
Hell of a grinder stand !!
Looks great!!
Old Wed 18 November 2015, 13:11
Look at my thread, I have 4:1, and already fixed many issues I found with other files and have removable pulleys etc.. can supply some files when needed.
Old Wed 18 November 2015, 15:47
Father-of-Ash
Just call me: Bilal
Toledo, OH
That's hilarious Mike, Thanks guys.
Fox I'll have to go through your thread again, too much stuff to remember.
I still don't know what I'm gonna go with and last night I slowly realized how much more work I have ahead of me lol. I would love to see what you have.
Also wanted to ask for recommendations on spur gear tooth count. with a 4:1 box would you go 25 or 30? from what I've read a 20 tooth is too rough on the rack and probably overkill?
Old Sun 13 December 2015, 23:19
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello All,
slow progress but coming along. Drag chains should be in tomorrow.
I didn't realize how bad my rails are until I recently looked at them carefully. I ended up milling the top of them and need to re-bevel, and i was able to bevel both Z's on the mill as well.
had a couple questions, but got a brain fart at the moment. hopefully I'll remember tomorrow along with a couple pics.
Old Fri 25 December 2015, 20:53
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello all,
just some pics of progress(not much) and an updated album link here.
Also, mrosupply.com seems to be the cheapest for Boston spur gears free shipping no minimum. $16.87 for 30 tooth and $14 for 20tooth.
Old Fri 25 December 2015, 23:36
Looking good
Old Sat 26 December 2015, 06:38
Its coming along nicely
Old Sun 27 December 2015, 22:54
Father-of-Ash
Just call me: Bilal
Toledo, OH
Forgot to say Happy Holidays to all in observance!
Thank you for all the help thus far!
Old Mon 28 December 2015, 03:52
The same to you Bilal!
Old Wed 03 February 2016, 23:38
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello all,
slowly its been coming along.
I ran into some issues with the rails and main beams, turns out the flanges of the C-channel aren't very perpendicular which in turn doesn't let the rails sit straight in the V-wheels. I've been belt sanding the outer part of the beam to try and level it out, im pretty sure this has been discussed somewhere here, i think i remember reading it. I was thinking of running some shim stock along the length of the rail for leveling but didnt think that was the best in the long run. I'll put some pics up tomorrow about this issue.
Old Fri 05 February 2016, 06:16
Nikonauts
Just call me: Nikonauts
Johore
Hello all,
Hi there, Bilal.
Flanges of C-channel not perpendicular to what? The C-Channel web?
Old Fri 05 February 2016, 14:20
This has been addressed in many machines.
Personally, I have done the following:
- tipped the Channel and welded the "leg" of the channel plumb when I build the machine \_/ or /_\
- Thin Layer of body filler (bondo) on top flange and sanded flat.
- used metal shims to plumb the Vee Rail.
All worked with varied success. Shims are quick and a soda can is a perfect thickness
Old Fri 05 February 2016, 19:40
Father-of-Ash
Just call me: Bilal
Toledo, OH
Yes they aren't perpendicular with webbing. I guess never assume the obvious????? Unbelievable...
Thanks Sean, I ended up belt sanding them, one beam is almost done , just needs some finishing touches. Had to use 24 grit alumina zirconia to see any progress but it's coming. Annoyingly coming along..
Old Sun 07 February 2016, 03:42
I belt sanded them to close enough to be shimmed and then shimmed the rails.
Old Tue 10 May 2016, 22:33
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello all, just chiming in.
not much progress in the past 2 months, but should be getting back on it now. I'll update that photo album as well.
Old Sat 14 May 2016, 13:31
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello all,
Can anyone recommend a ethernet smoothstepper that has plugins for both mach and UCCNC? or do they exist? not sure why since i dont know either of these programs yet, figured i might switch over to UCCNC down the road because of some very positive hype about it.
And if it doesnt exist then what is the recommendation for an ESS for mach3,4? I already have mach3.
Old Sun 15 May 2016, 03:57
CNC drive has a motion controller with ethernet which works with Mach or UCCNC
UC400ETH ethernet motion controller
http://cncdrive.com/MC/UC400ETH%20da...ETH_manual.pdf
Old Sun 15 May 2016, 13:33
Father-of-Ash
Just call me: Bilal
Toledo, OH
Thank you Danilo,
Discovered Warp9 tech seems to be very popular as well and a lot more options, and they said they will be developing an SDK soon for it to be more versitile.
http://warp9td.com/index.php/products
Old Sun 15 May 2016, 13:49
At the rate of mach updates and bugfixes some of us may not live to use more versatile SDK
Don't know what could be supported on smoothstepper that is not on other devices which work with Mach3 or 4, so the performance is similar. UCx00 devices work with mach3 and UCCNC. others will work only with Mach3,4
I personally have Usb smoothstepper and pokeys57e and couple of CSMIO devices, just look at the update rate and bugfixes for each and it will show you which device is in development which is buggy and which is mature.
For me CSLabs CSMIO IP/M for machines not needing lots of IO is perfect... works with 24VDC IO and has analog IO no need for interface boards or anything like that, nice package not a board which is awkward to mount or fragile, no interference whatsoever and no bugs to speak of in plugins.
Old Sun 15 May 2016, 18:44
Father-of-Ash
Just call me: Bilal
Toledo, OH
Ok I'll look into those Danilo, Thanks for the advice.
Old Mon 10 October 2016, 23:43
Father-of-Ash
Just call me: Bilal
Toledo, OH
Hello All,
Just wanted to chime in, I'm still around.
here is a link of photos of where I'm at. https://goo.gl/photos/b2YK7z6tCxumeoKT8
Starting My Build, Thinking of Linux - Toledo, OH TheDave Introduce yourself and start planning 15 Fri 20 August 2010 11:42
