Old Sat 11 July 2015, 06:39
Limit Switch Problems
It has been a long time since I have had any problems with my machine. I have forgotten some things. So I can use some help reminding me.
Yesterday, I was cutting and had no problems. Today, I am resurfacing so I can replace my spoil board. I kept having problems with my limit switches.
I did check to see if the E-Stop switch are good. They work and are not causing the problem. The limit sensors do not have any thing between them and the metal. They are not loose. The wires are screwed in tight. The relays are not on. Which I think the indicator light should be on.
I did not have a meter to check power etc. I am using proximity switches.
Please remind me what I need to look for. Thanks
Old Sat 11 July 2015, 10:44
After doing some trouble shooting, I think the problem is a cable is bad or a connection with the cable is bad. I have discovered that the proximity sensor is good as is the relay. I have a z sensor which I am not really using so I might just use that for the y sensor.
VFD & motor spindle safety switch Hans 60. Wiring & Cable Management 20 Tue 24 December 2013 04:47
configurable limit switch. for multiple uses. zumergido 70. Control Systems 0 Thu 27 September 2012 10:39
4 inductive proximity switch selling renraku The Market Place 0 Sat 23 June 2012 07:02
VFD Control Switch Question MAC2009 70. Control Systems 6 Tue 27 September 2011 05:39
Isolator switch ? andyclarkecncuk 70. Control Systems 12 Wed 24 June 2009 11:46
