Old Sat 06 December 2014, 13:35
Estlcam
While roaming the youtube I stumbled about this CAM software.
http://www.estlcam.com/anleitung.php
Seems pretty capable and very affordable (50 usd or 35eur)
It has all that you need, pocket, profile, preview toolpath and 3D machining
I installed it but had no time to test all the functions. Has Linuxcnc and Mach3 postp.
It even has a implementation of trochoidal milling toolpath, its a toolpath where the endmill is engaged at full depth, maximize axial chip thinning and allow much higher feedrates. Don't know if this is usable on wood thou
http://www.estlcam.com/100w.php
Forgot to mention ... its capable of sending the gcode directly to Arduino Uno and therefore control the machine directly . INSANE
Old Sun 07 December 2014, 03:41
Duds
Just call me: Dale
Canberra
Great link!
I particularly liked this video http://youtu.be/T4fn-tP1PuI that also demonstrates the trochoidal cutting technique really well. I learned something tonight.
Old Sun 07 December 2014, 22:36
Very nice! Thanks for the link!
Old Wed 10 December 2014, 09:59
digit
Just call me: Dominic
Quebec
That website and software is in Deutsch. Is it possible to get website and software in English ?
Old Wed 10 December 2014, 13:57
racedirector
Just call me: Bruce #122
New South Wales
If you use Google Chrome browser it will translate it for you
Old Wed 10 December 2014, 14:01
digit
Quebec
At least the web page. What about software :s
Old Wed 10 December 2014, 14:08
Don't know where do you see only Deutch?
Links I posted point only to english pages and software is in English language
http://www.estlcam.com/downloads/Estlcam_setup7.exe
Old Wed 10 December 2014, 15:45
digit
Quebec
Both with chrome et firefox the page is in Deutsch here.
Might be something with his server.
Old Wed 10 December 2014, 21:12
I get English page at 1st try.
Old Thu 11 December 2014, 04:38
Duds
Just call me: Dale
Canberra
I've been using ESTLCAM and found it a very good application the webpage and the application are a mix of German and English but the application is simple to use and makes good gcode. I really like that the output code is marked up with comments and messages.
Old Thu 11 December 2014, 14:10
racedirector
New South Wales
Tried this myself and just couldn't get it, must be a bit slow. No undo, can't deselect anything you select by accident and a few other issues. I'll stick with Cambam thanks....
Old Thu 11 December 2014, 14:32
Duds
Just call me: Dale
Canberra
Bruce, what version of CAMBAM are you using?
Old Thu 11 December 2014, 14:33
racedirector
New South Wales
Dale, using .098N and just looking at the about window I have 38 evaluations left
Old Tue 17 March 2015, 23:44
notimeforwork
Just call me: kwguy
kitchener, ontario
Estlecam is a very economical choice for beginners learning cnc. It does have its drawbacks - it only handles dxf files with single layers, and with that limitation it doesn't do 3d surfacing as someone suggested.
It is very easy to learn how to use, and is a perfect stepping stone to something a little more complicated and pricey. I've used estlecam on and off for about 6 months. With it I was able step up my understanding of cam programs enough to attempt to comprehend the benefits of a cad/cam package program.
Old Wed 15 April 2015, 10:04
notimeforwork
Just call me: kwguy
kitchener, ontario
Latest two versions of Estlecam do have a rudimentary 3d surfacing feature. It will handle an STL file and gives you few machining strategies.
