Go Back   MechMate CNC Router Forum > Computing, Software & Programming > Utility software
Old Mon 29 September 2014, 05:40
alan254
Just call me: Al #95
mystic ct
just ordered mine
looking forward to using
thanks al
Old Mon 29 September 2014, 05:57
ger21
Just call me: Ger
Detroit, MI
Thanks for the support, guys.
Old Fri 03 October 2014, 03:06
AuS MaDDoG
Just call me: Tony #71
Brisbane
Just ordered mine too
Looking forward to getting the time to play with this awesome piece of software.
Great work Gerry.
Tony.
Old Fri 03 October 2014, 05:55
Just saw its now available. Headed off to work, but I'll get a copy headed my way this weekend.
Great job, Gerry.
Old Fri 03 October 2014, 05:56
Andrew_standen
Just call me: Andrew #109
Dorset
Just ordered mine.
Great work Gerry.
Andrew
Old Sat 11 October 2014, 20:23
ger21
Just call me: Ger
Detroit, MI
Box Joints
Now that I have dovetails finished (except for some minor bug fixes), I started playing around with box joints. Probably a few months away, but I wanted to cut a test to see how they'd come out.
Old Sat 11 October 2014, 20:52
Much looking forward for this one too
Old Fri 17 October 2014, 05:32
AuS MaDDoG
Brisbane
Looking good Gerry
Tony
Old Wed 05 November 2014, 18:19
digger
Just call me: Milosh #113
Toronto
Ger, looks great.
Are you planning to do something about Knapp joint too?
Old Wed 05 November 2014, 19:29
ger21
Just call me: Ger
Detroit, MI
Had to Google that one.
No, I probably won't be doing that one.
But I do plan on a rounded finger joint, which is a little bit similar.
http://leighjigs.ru/images/companies...NGER_Joint.jpg
http://www.leighjigs.com/data/1054938350.jpg
Old Wed 05 November 2014, 19:38
ger21
Just call me: Ger
Detroit, MI
Here's the assembled joint from above. I think I have the standard box joints finished, just have to fix the preview that I broke when I got everything else working.
Old Sun 08 February 2015, 16:09
ger21
Just call me: Ger
Detroit, MI
Been working on this for the last month or so. Found a minor issue when I cut this, but should be releasing a new version soon.
Old Sun 08 February 2015, 17:21
Looking good !
nice to know these variable.....as I've yet realty tried it / pushed it sins I bought it
Old Sun 15 February 2015, 07:58
ger21
Just call me: Ger
Detroit, MI
I know a few of you have had issues with the JointCAM interface, due to the use of large font settings in Windows.
I've uploaded a new test version that now scales all of the controls to the window size, allowing you to make the window bigger to fit everything. I've only changed the Config and round box joint sections, but I'd appreciate any feedback on it.
I'll be moving forward on redesigning the entire interface. The scaling issue will only become more common as more people move to higher resolution displays, which often require larger font sizes to make text legible.
CNC wood joints normand blais Golden Resources 33 Fri 28 October 2016 12:22
Producing mortise and tenon joints kentster General - MM Operating 4 Thu 28 July 2011 06:25
Plug Tails (instead of dovetails) lumberjack_jeff The Show Room 5 Thu 02 December 2010 21:47
Cutting Dovetails on the MM WTI General - MM Operating 1 Wed 26 November 2008 22:28
Cutting Dovetail joints WTI Archives 19 Wed 24 October 2007 20:47
