Old Fri 30 August 2013, 05:13
Bosch GWS 7-125 Professional Grinder Skate Modification
Hi all
For years now I have been meaning to post these drawings (every time I read that a grinder does not fit the skate).
I did this as I only ever use 125mm grinders and wanted to get some more use out of it after grinding the rails.
These are an altered set of drawings that fits the larger Bosch GWS 7-125 Professional 125mm grinder.
The hole positions where the grinder bolts to the plate will require no alteration.
The throat has also been widened to fit the larger 125mm disk.
It would be advisable to print out the drawings and check fitment.
Grinding Skate 125 MM Bosh Grinder GWS 7-125 Professional.zip
Old Fri 30 August 2013, 08:01
Thanks for this and I guess it is a good time to take a look at these drawings in general for the skate to see what we need to do to get the next roundof parts upated to make sure the skate requires less mods t.o work with the newer grinders.
Maybe if folks can send pics with deminsions of a few brands of newer (less than 3 yea old) ginders would be a good place to start.
I have a Porter Cable I will take a look at this weekend.
Old Fri 06 September 2013, 08:21
silverdog
Just call me: Sergio #70
Rome
Italy
Those new 125mm grinders help a lot on cutting the rails, avoiding the contact of the skate on the uncutted 60mm L profile .... Althougt I used to cut the rails the 125mm disks on my old 115 bosch grinder with success and no problems. But grindig the V-shape need some modifications as Ross pointed out.
Old Fri 06 September 2013, 10:42
Mrayhursh
Just call me: Hurshy
Riverview, Florida
1st Order for Skate
Metalhead
Put me down for a skate that fits porter cable grinder
Some alternatives to Bosch grinders for skate dmoore Rails & Rollers 17 Mon 22 March 2010 03:47
Bosch GMF 1400CE Router gixi 50. Toolheads 5 Sun 12 July 2009 05:03
K2 Hitachi Router Mount Modification using SteelMax Saw dmoore 50. Toolheads 5 Thu 22 May 2008 16:54
Handmade V-Rails - "JR Skate" has 4.5" grinder riding the rail J.R. Hatcher Archives 93 Tue 23 October 2007 09:37
Handmade V-Rails using a baby 4.5" angle grinder - moving rails over grinder Gerald_D Archives 23 Wed 26 September 2007 22:46
