#31
Well done Andrew! Why do we have so few MM builders from the UK?
#32
Not sure Gerald.
I didnt find anything too difficult and this forum has all the answers if you look hard enough. Could be the cost. Every time you see a dollar sign I see 2 pounds. I purchased a lot of parts from the USA as the UK parts were so expensive even after shipping and import taxes the American parts were still cheaper. In some cases still 50%. If anyone in the UK reads this and needs help, just ask me. I'm no expert but I can cut parts now. Talking of cost.... Mechmate decals !!! Trying to find some that i can afford, been quoted £60 , thats too much , and i need them to apply for a build number, but I'm not paying UK prices. After all that, I have a smile on my face like a Cheshire cat , ear to ear. And I have a Mechmate cnc machine. Thank you for all your work. Regards Andrew |
#33
I often wondered that as well. Never thought about the cost with the added taxes that you guys have over there but that makes sense. You did a nice build and now you have bragging rights. It is nothing anyone can take away from you. As far as decals, Metalhead might be able to send you some. They are $10 here in the US, I do not know your currency there.
#34
now with decals
Is it good enough for a build number?
Its fantastic to use |
#35
Photos re sized
#36
Outstanding! Looks like your ready for that serial number! Congrats on a great build.
#37
Congratz! Now the real work begins
![]() Cheers |
#38
Whoop! Great!!
#39
Congratulations on a great job!!! You now go from builder to operator and that's where the rewards await.
#40
Cutting up scraps of timber, maple, oak and walnut
#41
Thank you all your kind words and help guys, now the fun really starts
#42
Great build !!! Glad you could get those logos local
!!! You get #109 |
#43
Thank you Mike.
Proud owner number 109 Andrew |
#44
Very well done, Sir.
Now the real fun starts.... |
#45
Ran the Mechmate for 3 hours last night. Largest card is 250mm by 430mm.
Maximum depth 2.5mm into 6mm material. Kept the good lady happy. And now I have a few more to make ! I want to make chairs...... but all this machine has done is to increase my honey list ! Lol. |
#46
Nice job!
#47
Updated Builder's Log
Andrew,
Congratulations on completing your build and earning Serial Number 109. Here's the Updated Builder's Log with your entry added. |
#48
Thanks John.
#49
Congratz on the build and your projects! This machine will change your life, good luck on the schooling, lots to learn
![]() Cheers! |
#50
If you mirror those tarot cuts and roll ink on them, you have a nice set of printing blocks. I've been doing a few of these lately and it works beautifully on the mechmate. I use Extira for mine because of the moisture resistance.
#51
Thats a good idea. Might try that. Cheers
#52
Having fun with this. Found a use for scrap ply from work.
#53
Very nice. I've never been able to get ply to look that good.
#54
Loving it!!!
Would you care to elaborate what that tooth brush is for? |
#55
Ken,
That is what he used to stain the wood. |
#56
Nils,
Thanks for the heads up. |
#57
Used Gaboon plywood scraps from work.
Nice clean 18mm plywood. Cam was aspire. Running mach3 Cutter onsrud 30-25 I think. 1/4 inch shank. 0.020 inch tip on 30 degrees Running at 2100 rpm. Feed 2500mm per min. 1.3mm depth of cut. One pass. Program ran for 2hours 3mins. Wax (applied with old tooth brush) is liberon bison black walnut. Comes up with a nice shine. |
#58
Opps that should read . Running at 21000 rpm.!
#59
Looks good.
Better than the plywood we get here. |
#60
Dolls House
Had to have a go at a makecnc.com dolls house for my grand daughter.
So I ran this on 6th mdf then painted it. 2.5mm cutter on 6th mdf. 12000 rpm 3000 mm per minute. 4th depth of cut. Result. |
| Progress on my Lathe project #23 - Plettenberg Bay, S.Africa | hennie | MechMates already cutting | 667 | Mon 23 December 2013 22:08 |
| Progress on Control Panel - Redwood City CA USA | oliver2257 | Construction started, but not cutting yet | 9 | Tue 17 January 2012 23:53 |
| Another Mechmate in Progress - Atlanta GA | Jay Waters | Construction started, but not cutting yet | 33 | Fri 22 April 2011 07:35 |
| Starting to make progress | peter__jackson | Construction started, but not cutting yet | 7 | Wed 27 October 2010 10:28 |
| My first cuts | bbreaker | The Show Room | 2 | Sun 22 June 2008 23:06 |
