Old Sat 30 March 2013, 15:10
Andrew_standen
Just call me: Andrew #109
Dorset
Hi Dave,
All looking good there, I know how hot it can get in Brisbane.
My grandfather lived out in Brisbane a long time ago, I stayed with him when Cyclone Wanda hit.... can't remember when that was.. 1975 I think ! a long time ago.
Any way I've been busy drilling the Z slide, should have that all completed this weekend, then its on to the welding of the spider.
Good luck with your build.
Andrew
Old Wed 03 July 2013, 01:14
BooY
Just call me: Dave
QLD
So i've got a bit more done recently, although not as fast as i'd would of liked but I haven't disapeared.
I now have the y car and gantry all welded up. the spindle has arrived, vfd is on order, my V bearings have arrived, and I've almost finished cutting down my rails to size ready to grind the V into them.
the rails I've cut so far have a .25-.5mm variance in height straight from the cutting discs. I'm hoping doing a grinding pass on them can smooth that out.
what variation is acceptable in the heights across the rail?
and is needs be is it ok for me to grind them down to 27-27.5 to get them perfect?
Old Wed 03 July 2013, 14:49
We all have unscheduled breaks in our build time. It is inevitable. Just stay with it and it will be done.
Old Thu 04 July 2013, 21:38
BooY
Just call me: Dave
QLD
Ok so i have a question.
I may have screwed the 1st X rail that i started cutting last night, note to self dont rush things at the end of the day to get it in before light fades.
I went out to continue this afternoon and have found that i must have been sleeping while cutting and have a 600mm section that has been cut to 24.5mm
Is this going to be a throw away angle now, or can i still get away with 24 if using the metric rail?
thanks
Dave
Old Thu 04 July 2013, 23:47
I checked on my MM & it seems that you can get away with 24mm rail, but the slot on the swing plat will be pretty close to the bottom.
IMHO, just dump the last rail & start a fresh. those angle doesn't cost an arm or leg, take that as a practice round
Old Fri 05 July 2013, 03:49
Also make sure your grinder set-up hasn't changed so you don't do it again. Maybe something loosened.
Old Fri 05 July 2013, 09:24
Another option is to change to hardened V-rails and and adapt as the cut off height needs to be lower to use the hardened V-rails. The cost is more but gives a long lasting running surface. Here in the US it was less than $300USD for me to do all of my axes. Only problem is you have to cut the rails with a cut off wheel. Tooth blades will not even mark the running profile only the mounting section is soft. I do not know the availability in your area so I would agree with Ken that new angle would be the best option.
Old Fri 05 July 2013, 18:34
litemover
Just call me: Chris
Auckland
New Zealand
Dont make the same mistake I did, be sure to use a large base melamine jig instead of just the laser cut plate with 4 bolts and take at least 25-30 passes on the cut. Very light cuts until you see smoke on the other side.
First Cuts And Has Stickers! #126 - Genesee, WI hflwaterski MechMates already cutting 215 Tue 11 April 2017 12:00
Mod woke up and gave #115 - Sacramento CA USA Zouave MechMates already cutting 173 Sat 07 June 2014 02:05
My Mechmate coming up - India Manjeet Singh Construction started, but not cutting yet 13 Sat 24 May 2014 22:49
Cutting 'Red Gum' Slabs for Table Tops - South Australia Quadro Miscellaneous / General / Whatever / Catchall 1 Wed 11 January 2012 23:23
Cutting mdf doors, laser coming? #1 - Sri Lanka fabrica MechMates already cutting 192 Wed 23 January 2008 21:17
