Long Table
I am considering building a table for use in cutting large fabric panels. My question is can the MechMate design be scaled such that the table size is 96 inches (2.5 meters) wide by 50 to 60 feet (15.25 to 18.25 meters) long?
There has been a 20 foot table done already.
20' long table, 5HP spindle - Port Aransas, USA |
Would the cables become too long at 60 feet?
Would all the cables need to be increased in size to combat signal loss and voltage drop? |
for the stepper power cable, at 3A@60V, I don't see serious voltage drop issue. but I do worry the small signals @5V@mA signal, you can always use 12V or better still 24V small signal config.
I think the limiting factor is more the span of the gantry and what tool it will carry than the x length. I'd sure consider drives and travel speeds carefully before jumping into it. As others have mentioned, the increased cable lengths will make wiring quality and sizing more critical and the potential for noise on these longer cables is increased.
Not familiar with fabric cutting. I'm assuming a swivel head knife is used? Wonder how many lbs of down force are required? Making hot air balloons? Chuck |
4mA - 20mA current loop ?
you can always set up a test rig with some batteries, a wire of the length you want & some resistors to limit to the current which you want.
| 1010322S Main Long. Beams - table edge carrying x-rails | Gerald_D | 10. Base Table | 118 | Sat 13 June 2015 23:07 |
| I have been wanting to build one of these for so long,... | cvriv.charles | General - MM Build | 66 | Fri 13 December 2013 19:35 |
| Build starting in Huddersfield UK November 2012 **table alterations & long Z axis** | mattmurphy | Introduce yourself and start planning | 3 | Thu 15 November 2012 05:36 |
| 20' long table, 5HP spindle - Port Aransas, USA | skypoke | MechMates already cutting | 42 | Sat 09 July 2011 18:07 |
| How many motors use mechmate in the long axis | albertoslayer | Motors & their mountings | 11 | Tue 09 March 2010 10:44 |
