Old Mon 22 October 2012, 14:27
alan254
Just call me: Al #95
mystic ct
laser scanner for mechmate??
Hi All,
I have several antique rossets I need to cut (all hand carved) and am wondering if anyone has played with a laser scanned mounted to a MM that can scan and send back info to a program thus creating a 3Dcut file.
This a new world for me and I am not afraid to experiment, but am not trying to recreate the wheel if it already exist.
Any ideas?
Al
Old Tue 23 October 2012, 06:59
Yes, yes I have - but it's pricey.
The more cost effective solution is a probe attached to your spindle using the "probe" input on your bob. Many MM users utilize this port as the auto Z-zero routine.
If the object your trying to duplicate is not to complex, then probing and storing the cloud data is a very robust solution. The probe can be made/or purchased for under a few hundred dollars plus the cloud resolution software.
The scanning is simple, but requires you to make up a version of the scanner from either a store bought solution or one-of-the-hundreds open source varients available. These scanner solutions require a lot of "post production" after the part is scanned to get it into usable form to replicate the object.
Again, not to scare you, it's all very obtainable - but it will require you to invest in the knowledge and time behind either technology.
this is an example of an affordable, passive, "high" resolution probe:
http://www.tormach.com/product_tts_passive_probe.html
Old Tue 23 October 2012, 17:11
Castone
Just call me: Leo #41
Soddy Daisy , Tn
Scan
Hi Al, I have a 3D scanner if you would like to make a copy of one of them and send it to me, I could scan it and send you a file to try, Leonard
Old Wed 24 October 2012, 06:14
alan254
mystic ct
Thank you both for the input.
I was thinking of something reletivly simple and I am using auto zero through my BOB.
My thoughts were:
To be able to mount laser in by spindle say in a .25" collet to maintain repetability between changes
By using a very narrow beam laser to keep focus on a object depth at a the specific location of the beam.
We can program the MM on a "flat defined" path at a known speed and track using our existing programing.
Feeding the laser output and the location from Mech3 to a program, not sure what one may be Excel, to plot the points at the appropiate locations.
Then,with this infomation create a 3Dcut file.
Input please
Thank you
Al
Old Wed 24 October 2012, 06:56
Have you seen this thread: ?
Laser scanning using a distance-sensing laser
Old Wed 24 October 2012, 08:04
http://www.david-laserscanner.com/wi...laser_scanning
This works...I have done it.
You would only need to build a file in Mach for the pattern movement of the laser.
This was actually the reason why I put the laser (crosshair) mount on MM #5 so I only had to add the camera when needed to scan.
Old Wed 24 October 2012, 10:37
normand blais
Just call me: Normand
montreal
The new version of David also work with Structured light (projector ) .It is much faster ,and you dont need the calibration pannel once it is calibrate . Also no moving parts.
Old Thu 25 October 2012, 04:48
alan254
mystic ct
Sorry Gerald I did not see that thread.
It was helpful, but it seams to have died may need new life.
I do have some ideas and will post after a little more experimenting
feel free to move this thread there.
Al
Old Thu 25 October 2012, 09:21
Why mount a sscanner on MM? If you can live with 1mm resolution; With ReConstructMe, You can turn a Kinect into a 3D scanner.
http://www.youtube.com/watch?v=LZZqffZkOw0
MechMate Laser Kit Parts in Portugal cerelak The Market Place 10 Fri 19 October 2018 12:56
MechMate Laser Kit Parts in the US ddoggett The Market Place 62 Wed 24 August 2016 10:12
MechMate Laser Cut Kits in Canada MetalHead The Market Place 29 Wed 23 December 2015 06:42
Mechmate laser cut parts nightwinter The Market Place 0 Sun 05 August 2012 01:15
MechMate Laser cut Kits in Australia MetalHead The Market Place 1 Wed 06 October 2010 15:11
