Need spindle that can work in 2 countries
Hi Everyone,
This is my first post here, so thank you for this incredible bevy of information. I live and work in 2 countries, US and NZ, and so I'm trying to figure out the best way to economically keep either 2 machines, or 2 shells of machines, one in each country, taking the guts to the other machine when I leave. I cut a lot of wood and MDF, at high production levels, with high detail and need power, speed, accuracy. I'm in the market for a CNC machine, hopefully something closed loop, at least 4x8, possibly larger table. But was wondering, what would be my best option if I wanted to port my spindle back and forth? What would be an ideal spindle to use that I could change the voltage on? Also, would need something that could get to 24000 r/m at the least, quite reliably. Any recommendations? Thanks, Chris |
I can't imagine dismantling the spindle and VFD all the time and carrying it with airplane (spindle 5kg, VFD 1-2kg).
Everyone have been happy with the value/price of chinese spindles but I have to recommend the water cooled 2.2kw or 3kw (depending on your application) one from Deitech, but for the VFD you should get some of the name brands (Hitachi, Omron, Yaskawa, Delta etc...) |
Just get a Main transformer 3 times the spindle rated power & install on the machine which doesn't match the spindle voltage requirement.
You still get to haul 3~5kg worth of metal across all major oceans. "at high production levels, with high detail and need power, speed, accuracy. " a 5kw water cool spindle should do the job for you. that is 6~8 kg. |
Chris |
Chris |
I am running DTS-23 for 1.5 years, no problems yet.
http://driver-motor.com/ProductContent.aspx?ID=58 Bearings seem to be much better than in some ebay ones. Friend bought from lovehappyshopping. His spindle sounds different...rough and louder, and the nut is out of ballance. At 18.000 rpm the whole machine vibrates and sings. Maybe thats just because of crappy Huanyang vfd... stay away from those. As much I like 2.2kw one as it can be run from single phase VFD, the 3 or more kW should be considered for production work just like Ken said. |
I would have to agree with Danilo on the Huanyang VFD. I had a lot of interference issues with mine, and after a long amount of trouble shooting I changed to a Hitachi and all my problems went away. I was getting interference induced into my limit switches and it was causing me E-Stops with no reason. I had tried all different types of shielding, grounding and isolation but nothing worked. Some have had success with the Huanyang VFD, but for the money I would not go down that path.
No problem with my Huangyang VFD. I operate it manually. Even use another unit to control my air compressor.
PS, not that it is 100% perfect, they have very poor touch pad which I'd replaced twice over already... |
I am also running the Lovehappy shopping (Huangyang?) VFD and spindle. No brands on either.
When this first ran it was like a sewing machine, rough! Once I had a solid earth on it (Not relying on earthing through V rollers and Aluminium mount) and had tightened the Z axis spider V bearings, all six, as tight as I could and get the Z moving still. It now runs very smoothly. I regularly check that I can not turn the V rollers by hand on my Z axis. I would not set up this every six months, I would get one for each site. |
#10
Cool, thanks for the info. I'll check Huangyang and see what he has to offer. Hopefully it won't take long to get it and I get a good one! Does it make sense to get a tool changing spindle?
#11
Just manage your expectation. For the money...
| Some great CNC design work | WTI | Miscellaneous / General / Whatever / Catchall | 9 | Wed 16 March 2011 21:25 |
| Cutting glass - would it work? | john doe | 50. Toolheads | 55 | Fri 24 September 2010 01:04 |
| Water Cooled Spindle Connections - Connecting the Spindle | waynec | 50. Toolheads | 32 | Fri 19 June 2009 12:31 |
| serious indexer work | normand blais | Miscellaneous / General / Whatever / Catchall | 0 | Mon 02 March 2009 08:02 |
| Laser cutting in various countries . . . . | vadeem | Archives | 12 | Thu 02 October 2008 07:02 |
