Old Mon 11 June 2012, 08:43
silverdog
Just call me: Sergio #70
Rome
Italy
Problem with Tabs ... it leaves vertical signs
Ciao,
I have this problem, when the machmate raise the mill do do the tabs, it leave vertical signs in correspondance of its up-down. A picture for better explaining.
Any idea ?
Sergio
Old Mon 11 June 2012, 09:05
Sergio use 3d tabs.The cutter needs to stop and then go up, move and then go down.
Old Mon 11 June 2012, 10:01
silverdog
Rome
Italy
I'm sorry Hennie, I did not understend. I understand that the cutter needs to stop and then go up, move and then go down, but did you do mean that that problem has no solution ? (Yes it's not a very big problem but I thought I have a z axis not perfecly squared to XY plane but I get the same problem on all the side of the pieces in any direction I turn ... )
thanks
Old Mon 11 June 2012, 10:10
The tab is like a little triangle meaning that the cutter moves up while it cuts forward.
Old Mon 11 June 2012, 11:01
Use the tab shape at the bottom:
Old Mon 11 June 2012, 11:16
silverdog
Rome
Italy
Wow.Ok thanks I understand now. I 'll try tomorrows.
Old Mon 11 June 2012, 16:27
Like many, I too have found that using 3d tabs solves the problem, but only if the CAM supports it.
Old Mon 11 June 2012, 17:48
silverdog
Rome
Italy
just becose we are talking of tabs .... does visualmill support 3D tabs ? and does visual mill let you choose where to put tabs ? (I mean exacli put the tabs where you want them ... like vectric's products)
thanks
Old Mon 11 June 2012, 17:54
looking at the videos here
http://www.mecsoft.com/Training/VMTo...thMethods.html
it shows only standard tabs
Old Mon 11 June 2012, 18:31
silverdog
Rome
Italy
thanks Danilo. I saw that new version has manual editing tabs but no 3dtabs
Old Mon 11 June 2012, 23:10
I knew someone would do a drawing
Old Tue 12 June 2012, 04:49
Jou bliksem, ek het gevoel hoe druk jy vir my!
Old Tue 12 June 2012, 07:12
Old Tue 12 June 2012, 09:15
silverdog
Rome
Italy
(google translate)
Old Tue 12 June 2012, 09:36
Google translate is a bit rough, but for Hennie they may be accurate. Actually we also use bliksem for scoundrel.
Old Tue 12 June 2012, 23:27
And it is so unique to our Mother language Afrikaans.It has some other meanings also,I am going to hit you,( Ek gaan jou bliksem!) or You are a noughty small boy, ( Jou klein bliksem .) or Look at that lightning .( Kyk na daai bliksem straal ) or If you were in a bar fight of some sort and you got the worst of it then we would say ( Kyk hulle het vir hom goed gebliksem .)
2 X Parker HZR100 vertical actuators kentster The Market Place 0 Wed 17 August 2011 00:27
Space-saving vertical table Helge F. Holm 10. Base Table 8 Tue 01 September 2009 20:05
How to do Signs Lessons sailfl Miscellaneous / General / Whatever / Catchall 10 Fri 06 February 2009 04:03
Vertical MechMate dullfig Archives 3 Thu 27 December 2007 20:19
Seating the Y-Car - V-Rollers' vertical adjustment slots fabrica 30. Y-Car 2 Sat 13 January 2007 20:15
