Problem with Tabs ... it leaves vertical signs
Ciao,
I have this problem, when the machmate raise the mill do do the tabs, it leave vertical signs in correspondance of its up-down. A picture for better explaining. Any idea ? Thanks Sergio |
Sergio use 3d tabs.The cutter needs to stop and then go up, move and then go down.
thanks |
The tab is like a little triangle meaning that the cutter moves up while it cuts forward.
Use the tab shape at the bottom:
Clipboard01.gif |
Wow.Ok thanks I understand now. I 'll try tomorrows.
Thanks |
Like many, I too have found that using 3d tabs solves the problem, but only if the CAM supports it.
just becose we are talking of tabs .... does visualmill support 3D tabs ? and does visual mill let you choose where to put tabs ? (I mean exacli put the tabs where you want them ... like vectric's products)
thanks |
looking at the videos here
http://www.mecsoft.com/Training/VMTo...thMethods.html it shows only standard tabs |
#10
thanks Danilo. I saw that new version has manual editing tabs but no 3dtabs
#11
I knew someone would do a drawing
#12
Jou bliksem, ek het gevoel hoe druk jy vir my!
#13
#14
![]() (google translate) |
#15
Google translate is a bit rough, but for Hennie they may be accurate. Actually we also use bliksem for scoundrel.
#16
And it is so unique to our Mother language Afrikaans.It has some other meanings also,I am going to hit you,( Ek gaan jou bliksem!) or You are a noughty small boy, ( Jou klein bliksem .) or Look at that lightning .( Kyk na daai bliksem straal ) or If you were in a bar fight of some sort and you got the worst of it then we would say ( Kyk hulle het vir hom goed gebliksem .)
| 2 X Parker HZR100 vertical actuators | kentster | The Market Place | 0 | Wed 17 August 2011 00:27 |
| Space-saving vertical table | Helge F. Holm | 10. Base Table | 8 | Tue 01 September 2009 20:05 |
| How to do Signs Lessons | sailfl | Miscellaneous / General / Whatever / Catchall | 10 | Fri 06 February 2009 04:03 |
| Vertical MechMate | dullfig | Archives | 3 | Thu 27 December 2007 20:19 |
| Seating the Y-Car - V-Rollers' vertical adjustment slots | fabrica | 30. Y-Car | 2 | Sat 13 January 2007 20:15 |
