#31
Check your table OFFSET. It needs to be a bit longer on one side to compensate for the rouer / spindle to reach each edge.
#32
Hello again,
I was wondering what thickness of the cable should I use for drivers? I have a several options, but dont want to overkill it. What should be the profile of the cables. About offset, did you mean the offset of the spindle? Here is the pic which could help. I think I should move it more towards the end. ![]() |
#33
Marko, notice how the router does not sit in the center of the y-car. The table offset means that one end of the table needs more clearance than the other (ie the beams need to be longer) to be able to reach the end of your cutting area.
As to your answer on cable thickness I believe this thread holds the answers. http://mechmate.com/forums/showthread.php?t=2 but its usually around 18 AWG. (i think) |
#34
I made that mistake and later had to weld small pieces of beams to the ends
thankfully I did not cut the rails to exact length of beams before I noticed the mistake. |
#35
You can use 4 core shielded, 1.0mm2 - 0.75mm2 per core for motors.
For the spindle 1.5-2.0mm2 should be sufficient |
#36
#37
Very Nice 3D views ! I wish mine looks as good as yours.
Pre-mounting in 3D helps me a lot in the understanding of the MM pinciples. I wish you the best for your build ! ![]() |
#38
Thank you,
And it really does help a lot when you have something build in 3d, its much easier to understand where and how things go and connect. With SW, i can determine the weight, very accurate measures so it can fit perfectly to the workshop. |
#39
Drilling has started, and some new parts arrived.
design ![]() Cant beat the real look. ![]() ![]() |
#40
Is there any benefit to use anti-vibrations feets instead of 100% metal ones ?
#41
Dont know, but there is an option to add rubber bottom on these feets. If the vibrations turns out to be a problem.
#42
Most people use them because they look sexy. Firm contact to the floor would be better in terms of cut quality. However, they reduce vibrations transmitted to the floor and reduce noise.
#43
Good ! The cutting quality is the main goal, so I'll save money with simple feets,
which are 4 times cheaper. Thanks. |
#44
Gerald, I have a question in private for you, but cant send you message.
Can we get in contact in any other way than this? |
#45
This is planning side ladder and fixing it up.
Below is my 1st weld done on that ladder. My experience in welding has reached for about 3-4 days, 1-2 hours per day. So I am pretty proud on that weld. Rest of the welding is in the same or similar quality ![]() ![]() image upload ![]() upload images Last edited by marko cro; Thu 29 March 2012 at 17:21.. |
#46
Good Job there Marko. Starting to take shape.!!
#47
Very nice work!!
#48
Good job.
#49
I was wondering where is my thread
![]() Thank you all, Today all the front and side ladder will be finished, then moving on to the assembly it with trestle. Will post more pics at the end of the day. |
#50
Well(d) done !
You have some nice tools to clamp tubes squared. |
#51
That tool made my life much easier. Regreted tho for not buying 8 of them ![]() Here are some pics from today work done. I have put it together just to get perspective. And it looks massive. ![]() ![]() ![]() After working its important to clean the work area, coz my workshop is a bit small ![]() ![]() Resting proudly at work being done ![]() |
#52
DIY aluminium control box. To build it, I had to make a tin knocker/bender, which is made from MM parts. Proof of concept, and it works.
Control box needs back enforcement in the back panel with some 150x150x15 aluminum plates. Heating wont be an issue here .Holes and ventilation will be drilled additionally. But so far, a decent box. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#53
I think it would have been cool to put a piece of tempered glass in the face of your door.
#54
Yes, tempered glass for a spindle controller, and a hole for a digital thermometer.
Also, for buttons, and E switch. Thanks for noticing ![]() |
#55
Great work marko!
#56
Nice box.
With the VFD in such close proximity to the motor drivers, I hope you have good grounding lay up later. |
#57
There's no problem in having a VFD that close to the drives.
My old machine was also mounted close to the drives, I had no noise what so ever from the VFD.. My new machine has 15cm more distance to the drives, and again, absolutely no problems with noise. |
#58
Not sure will I have noise, but I was thinking of making additional box for spindle control, with air flow connected IN and OUT to outside of the workshop, due the dust accumulation.
In the calibration phase, I shall see if there will be noise. Also, I am looking for a good plan for a spindle mount, which should be made of aluminum. EDIT: I am looking for cutting aluminum, how does a MM act in engraving and cutting aluminium. Does my spindle speed @ 24000 RPM is 2 much to cut it. Would be the Z-car too light for a aluminium, and should I fill it with sand .Last edited by marko cro; Thu 12 April 2012 at 16:31.. |
#59
Marko,
Many have successfully cut aluminum on a regular basis. One machine, a 8' x 21' machine was built to cut primarily alum sheet for a boat manufacturing business here in the US. |
#60
Hi Sean, Thank you for your post. The plan was to work with aluminium and wood, and some softer materials, and lately, i was starting to doubt the MM can work on aluminium.
I saw some videos and I think I will be fine in that area. |
| First Project Completed! #106 - NL Canada | cleyte | MechMates already cutting | 48 | Tue 23 May 2017 22:42 |
| Not a MechMate but it is cool | sailfl | Miscellaneous / General / Whatever / Catchall | 10 | Thu 06 May 2010 15:59 |
| Free Software and other cool stuff | seaboardironworks | Graphics & CAD | 0 | Sun 25 April 2010 08:29 |
| On to other Cool Projects #43 - Arad, Romania | Claudiu | MechMates already cutting | 205 | Thu 25 February 2010 00:07 |
| Cool front panel joint | WTI | Miscellaneous / General / Whatever / Catchall | 0 | Sat 07 June 2008 16:53 |
