#31
....I love it when people follow directions! Good work - nicely done.
#32
I SHOULD have the base table final welded and upright by the end of the week.
So now I'm exploring PMDX numbers like mad, trying to decide how to best build a control box that will allow me to use the proxies I already have, and be able to add a laser pointer, touch off plate, spindle control, dust collection switching, etc. in the future without having to backtrack. Then there is that whole smoothstepper question..... If anyone has any insite to a plan of attack, I'd be very appreciative. |
#33
go for the PMDX 126, plenty of inputs, and if you decide you have more then that can handle, you can add a second 126 to the mix. but out of all the boards, that has the most inputs and outputs (i think).
#34
I agree with John. go the 126 route and if your using Geckos use the 133 or 134 boards to reduce wire clutter in the cabinet.
#35
That is the way I was leaning.
Thanks for the replies. Anyone have an opinion on using these type connectors to connect to the control box? http://www.pmdx.com/4Pin-PlugAndJack |
#36
http://www.ebay.com/itm/270712985784...84.m1497.l2649 Than it is to pay $6.00. Get a few extra for later servicing. |
#37
#38
Man I learn something new everyday.
Hours spent reading threads and seeing comments about XLR connectors, and I STILL didn't make the connection that those are XLR connectors. Thanks for the link. D. |
#39
BTW, got a couple sheets of 3/4" x 5 x 12 MDF headed this way....
Anyone wanns help unload it? My back hurts already... |
#40
Actually, the ebay connectors referenced in the above posts are not really xlr connectors. They will work fine but are not interchangeable with real xlr connectors as far as I know.
#41
#42
http://www.markertek.com/Cables/Audi...FX.xhtml?NC4MX
Markertek is a very reliable source with pretty fair pricing. Customer service is awesome. These Nuetrik 4 pins are the industry standard. They are also only one of the few xlr that are rate for the current and voltage the stepper motors require. Myself, JR and a few other used them. Good luck. |
#43
Oh Suuuuure, everyone jumps in with more connector info, but nobody offers to help unload the MDF????
Just kidding, thanks for all the info. Spending a few bucks more on good components to have a reliable machine is well worth it in my mind. I don't mind doing something, but I ABSOLUTELY HATE having to redo something after the fact. Table should be upright by the end of the week.....probably massively overkill too.lol |
#44
Nuetrik is a great brand for connectors.
Besides XLR, you can also look at the SpeakON style connectors. They come in 2, 4 and 8 conductor layouts. These are made for high current usage and basically unbreakable. You might even use both styles to make it hard to mix up motors, sensors, spindles.... |
#45
Table is turned over onto its six legs....Now if I could only find my camera.....
#46
...it's under the table! LOL. Great accomplishment - keep up the great work (we are watching!)
What I really want is a picture of you moving the MDF. If I recall when I took care of my MDF move, I actually put 2 trash cans on furniture dollies to move at the same level as the truck bed, to the machine bed of the MM to keep the lifting to a min. That is some HEAVY stuff. Be careful. |
#47
Going to order cable chain from Mcmaster tomorrow (4516T22)
The formula I found is 1/2 the axis length + 2" + (radius of chain x pi) +1 link.. so for a 5x12 I need: X axis = 144"/2=72"+2"= 74"+ (12.377")= 86.377" Y axis = 60"/2=30+2=32"+ (12.377")= 44.377" 86.377+44.377= 130.754" Less than (2) 6' lengths. Plus end brackets... My question is: can what I take off the Y axis be added to the X axis, or will that not work? Is it like a bicycle chain where you need a "master link" ? |
#48
The IGUS energy chain is modular. Each link snaps into the next very simply. The end links are just the same. Just make sure you snap in the proper direction, they are "handed" links.
If you order another 12"-18" and 2 ends you can also do your z-axis! Good luck. |
#49
Found the camera....luckily not under the table.
My wife wasn't happy when I told her I flipped this over by myself using a floorjack and chain hoist...... probably good that I don't have any pictures of that. ![]() |
#50
It looks awesome Darren!
I work by myself a lot. I know what its like. Sometimes things are safer than they seem when there's only one person to worry about getting hurt. I find I can do a lot more than I thought, very safely, if I just go slow and plan every move and back away and look everything over a lot. I would have turned it over by myself to and also would have been fussed at ![]() |
#51
@Darren: Do you think those beams will hold that table? !!!. Kidding, that looks great. Looks like it's coming together nicely... Good Job!..
#52
LOL, like I said, massive overkill.
I suffer from a disease called "while I'm at it" that always makes things escalate... I can tell you, it is rock solid. |
#53
I'm waitin for someone to use an electric pallet jack setup on one of these to move it around
!!! Nice looking table !!! |
#54
Looks about right to me. Nice work.
#55
Awsome looking table!!!
That is a sturdy table there! You will be rewarded for the extra miles on the additional weight & diagonal braces. |
#56
Got some used cable chain and installed it, and it seems to sag a bunch.
Does this look normal, or am I doing something wrong? ![]() |
#57
As you said, that cable chain has seen a lot of use and is a bit worn, but still functional for your application. Check that the links are still firmly attached to each other by jerking it around a bit - that is the most important thing. If it droops so far down that it slides on the lower part of the chain you will have to check that it doesn't snag. (On very long machines it is normal for the chain to drag over the fixed part)
#58
Darren...have to say that is a beast...wow...
I knew the 12' long would add some "bulk"...didn't think that much :-) |
#59
Thanks...I think....
![]() Heres how it looks today with a 61"x145" MDF spoilboard Just painted it yesterday. Hope to get some re-assembly done this weekend.. ![]() |
#60
VERY nice...
| University Of Missouri Saint Louis Theater | ganderson | Introduce yourself and start planning | 8 | Fri 31 October 2014 18:53 |
| Starting my MM Build - St Louis MO USA | inventek2000 | Construction started, but not cutting yet | 38 | Sun 25 September 2011 18:51 |
| my machine cnc | marcoscnc29 | Archives | 1 | Sat 24 April 2010 18:58 |
