Thanks Greg.
Strange as it may sound....I am almost sad that it is complete. I spent so much time constructing it over the last four months, that I kinda miss heading out to the shop to mill, grind and drill the parts needed to make the machine. The machine is now truly complete. I put the final touches on the wiring yesterday....connecting the limit and home sensors, also hooked up my auto-z circuit and built the touch plate. The touch plate plugs in using a standard bananna jack...this allows for various styles of touch sensors to be quickly installed. The touch plate shown in the picture is solid copper, it is machined to exactly .25" thick. The copper came from piece of test equipment (ground bar).....it was originally 8ft long ![]() |
Any clue on a thread that explains fully how to implement the z-zero plate?
try here on forum
http://www.mechmate.com/forums/showt...hlight=croatia or on the zone directly its pretty straightforward http://www.cnczone.com/forums/cnc_wo...tool_zero.html and here http://www.cnczone.com/forums/mach_w...r_big-tex.html |
