Old Wed 30 November 2011, 19:09
SLINK
Just call me: SLINK
CHURCHVILE NY
Best price 4 /1 timing pulleys
Looking best price to make a 4 to 1 ratio timing pulley reduction
could really use exact part numbers and matching seller sites
really need to get my cost down going broke no overtime in this bad economic situation and i am now at the point of just buying parts i am not making
Old Wed 30 November 2011, 21:36
I have complete sets of 4:1 that I can ship. Also if you need them I have axles and bearings that will work in my motorplates or in other plates.
Old Thu 01 December 2011, 15:37
SLINK
Just call me: SLINK
CHURCHVILE NY
A complete set being 3 sets two sets for my x axis and one set of my y axis?
Also belts to match
my machine design is a variation of mechmate so motor plates are different still a gear rack design
Old Thu 01 December 2011, 18:54
What about your z axis? You need 4 really.
x1
x2
y
z
are the required axis motors
Old Fri 02 December 2011, 16:16
SLINK
Just call me: SLINK
CHURCHVILE NY
Smrish i have totally built screw drive for the z axis sorry i didn't explain this i have thirty yrs of machining exp. And i have really design my machine as a cross between a mechmate and another machine my next machine will be completly different given and easier way to make parts not on a manual mill
Old Fri 02 December 2011, 21:00
I didn't use a mill to build my MM; I don't have to
Old Sat 17 December 2011, 12:32
pistolpete
Just call me: pete
Fort Erie,Ontario
Mike, I need a set of timing pulleys, just 1 pair. need 1/4" bore for motor and 3/4" bore for driven. do you have and do you take paypal? thanx....pete
shaft coupling or timing pulleys? coinhunter Construction started, but not cutting yet 4 Sat 16 July 2011 01:57
Source for timing pulleys DTGuitars Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 4 Tue 05 October 2010 08:39
Toothed, Timing Belt Suppliers Victorian Signs Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Sun 16 August 2009 01:03
Timing pulleys made easy stcnc The Market Place 0 Mon 08 September 2008 16:02
Steel price increasing ekdenton Archives 8 Mon 14 April 2008 07:43
