Router speed control
Since this is the router area I use a Hitachi that has a dial speed controller. I think that the milwaukie and the hitachi are the same btw
Can I wire that dial speed controller in the top of the hitachi/milwaukie to the electronics of my cnc?Thoughts? Coog |
Out of curiosity, could anyone sketch a typical scenario where they want the router to make speed changes while they are not near to the machine?
"...want the router to make speed changes..."
This may not help, but Harbor Freight has a variable speed router control for twenty dollars. I don't know if it can be adapted for this use... Bill McGuire |
Folk must be aware that reducing the router's speed with the typical speed controller, leads to a very significant drop in torque. The only way to recover torque at low speed is with belt pulleys or gears. You can't leave your car in top gear and then try to drive at 10mph by using the gas pedal as the only controller. Spindles almost maintain their torques at low speeds - but they do loose HP (power)
using an electronic speed controller is for a couple of things. 1 is to set the speed in the gcode for the material selected and 2 is to turn on/off the router at the beginning and end of the gcode also.
It would be nice to get control completely in mach3 is all. Coog Last edited by coogrrr; Thu 04 October 2007 at 06:59.. |
One quick input, then I'm gone for a week to the mountains
. I still don't see a reason for speed controller speed control. Maybe your cutting one material, and then transition to another material of different density. It seems like allot of work for a little return. Just thinking out loud. Gerald's original question - could anyone sketch a typical scenario where they want the router to make speed changes while they are not near to the machine? |
2. "turn on/off the router at the beginning and end of the gcode" That is something completely different to a speed control - that is a simple relay, that function is already built in. An automatically speed controlled router makes sense if you have an automatic tool-changer, but you havn't mentioned this so I don't think you really need to go all trouble to twiddle a pot (2 ports, driver, etc.). Bear in mind what I said before - you loose lots of torque. So you might want to go for a VFD controlled spindle . . . . . . . |
Copied from another thread:
Thanks Gerald, One more question, I think I am not bothering you. Should I go for Makita 3612 C (2300watt (3hp) Eletronic control) or Makita (60mm plunge depth, 1,850 watts (2.5hp)) http://www.makitaindia.com/beta/desc...12C&category=5 http://www.makitaindia.com/beta/desc...2BR&category=5 I am asking you because I have read in forum somewhere that Electronic control should be removed while mounting router. Regards. |
#10
We use the 3612C (with the handles removed) - it starts okay with normal relay or contactor. I don't know if a Solid State Relay (SSR) will start it. It is a good, tough router.
#11
Thanks Gerald,
If the Dial up variable speed:9000-23000rpm is usable of this router in Mechmate ? ![]() |
#12
I don't know if I understand your question. You definitely want to have variable speed. I don't see how it can work with one speed only. Cutters have a big range of diameters - small ones turn fast, big ones go slow.
#13
Gerald.
Like spindle one can set rpm while cutting (while gantry moving) through VFD if cutting speed doesn't look satisfactory for a particular job. But since electronic contol of router is on router itself, how one can set rpm while cutting job is going on ? rpm of router can be set before job work starts, but if it is not slow or fast enough then how to set router rpm again - (1) pause - set rpm - resume. (2) or any other method. I don't know if it is a dumb question, I asked because right now I don't know and I don't want to regret later if I am shy away. Regards, |
#14
Speed control during cutting with the router will be as you are thinking - stop the cutting, change the speed, start the cutting. Unless you can reach the control on the router with your hand (seldom easy).
For the spindle, Mach has got a facility to change the speed from the keyboard. But, if we use the parallel cable and PMDX-122, we cannot use that facility. You need diffent hardware to get the spindle speed to work from Mach3. However, with the spindle, it is easy to reach the VFD's control while the machine is cutting. |
#15
I have had several variable speed routers apart, over the years, to change bearings. I remember the speed control as being a separate electronic device incorporated into the router body. I wonder if it is possible to remove the speed control and install it in a remote (from the router) easily accessible position. Don't know if it is possible. Just a thought.
Paul |
#16
If speed control unit is separable than there is a possibility that this can be mounted with push buttons on gantry.
#17
One can buy general purpose speed controllers for small power tools (similar to light dimmers), but there could be a huge difference in quality between different types that may result in damage to the tool.
. . . . . had to say that before the classic discussion on speed controllers starts all over again ![]() Sharma, I don't know if the Makita controller can be moved easily - will you let us know? ![]() |
#18
Paul, the Milwaukee controller uses a feedback signal from a speed sensor on the shaft. But there is a company that does a special remote speed control for the Milwaukee.
#19
Right now I don't have one. When I have one I am definately experimenting with it. ![]() Here is exploded view of 3612 C, part no. 3 is control unit, which can be extended upto gantry side. Any comments ? |
