#331
Hi All
Yes the bearing is at the bottom of the straight cutter as Gerald has indicated. The bearing follows the machine cut part of the profile and trims the tabs off. Even once the part has been cut free any roughness can be further trimmed freehand. In general though, the machine itself should do as much of the work as possible. If the table is set up well trimming of very thin tabs can be cut with a "Stanley" knife (a very sharp cutting blade). Regards Ross |
#332
If the job is small enough to manipulate hand; I prefer to place a piece of sand paper on a flat surface & bring the job to the sand paper, all it need is a single rub at the right direction on the edge.
#333
Silly me ! the board is turned over and then trimmed, then its easy to figure out why use bottom bearing
#334
HI Melissa,
Looking at post 309 the V-roller appears to be pitted. Maybe just pitch form the wood or is there some grounding issues. I noticed you have ground wires. Boxes look great. On the inside corners of the tabs did you go back and trim them square to get your fit where the matting side comes together? Last edited by domino11; Wed 13 August 2014 at 10:35.. |
#335
Gary, as I recall, the black on the V-rollers was just crud building up, not electrical arcing.
Also, yes, we trimmed the tabs to get the pseudo-dovetail to seat fully. |
| dust collector capacity | gorantec | 55. Dust Management | 15 | Thu 19 November 2009 19:24 |
| Dust foot and custom clamps done #3 - Conway, AR | Doug_Ford | MechMates already cutting | 195 | Mon 13 October 2008 20:27 |
| Dust collector foot | Marc Shlaes | Dxf Library | 7 | Sun 27 April 2008 19:18 |
| Dust Collector Foot | Doug_Ford | 55. Dust Management | 34 | Fri 04 April 2008 10:01 |
| Dust collector foot | Art | 55. Dust Management | 5 | Sun 17 June 2007 13:09 |
