Problems working the end of some Ballscrews
I have some problems working the end of some screwballs, they are really hard and the lathe doesn’t “clean” the thread of the screw, I think that it would be a good idea to heat them in order to “soften” the metal, is it a good idea? How can I solve this problem, thanks for your help.
use the grinder to remove the top cemented coating, then machine the soft insides.
And use ceramic inserts as they should be rated for 65hrc, if you go real slow with them you can skip the grinder, but its the easiest way. |
So is this a MechMate using ball screws ?
It is a homemade CNC machine, the model doesn't look like a mechmate. I don't know how a "Mechmate" moves his axis, in my case they are moved by the ball-screws.
The material is case hardened and around .06" deep depending on your ball screw size. Use carbide and get your surface speed down to where it should be, And the tool will bite and cut real nice. The material is soft under there after you get thru the case of the material. There are other materials that will cut it just fine but not as forgiving. Fosus on the right rpm based on the surface speed needed and you will be good. Just don't work harden the material. There are many factors that may contribute to your problem, so it's hard to list them all. Good luck!
| Working on Belt Drive - Randers Denmark | IN-WondeR | Motors & their mountings | 0 | Sun 09 January 2011 07:23 |
| Working Out The Table Plan | dakmonf | Introduce yourself and start planning | 32 | Wed 30 June 2010 11:59 |
| Power Contactor Not Working | Regnar | Troubleshooting | 28 | Sat 10 April 2010 12:38 |
| Working with CAM Software - Shawinigan, Canada | m_leblanc | Introduce yourself and start planning | 28 | Sun 21 March 2010 23:53 |
| Experience on working with V-cap rails | 711man | Rails & Rollers | 0 | Mon 21 September 2009 08:03 |
