Old Fri 28 January 2011, 10:39
melissa
Just call me: Melissa #83
Brighton (Ontario)
Drilling / Welding the Spider - Order of Operations?
I just wanted to be sure about the order of drilling / welding the various bits on the spider (10 40 432).
- drill and tap six holes, M8 (10 40 432 D)
- use temporary bolts to hold nuts (10 40 432 W) and bearing supports (M1 20 220 T) in place on the spider
- weld the nuts and bearing supports
- remove temporary bolts and flatten the spider as necessary.
Does that all sound correct?
Old Fri 28 January 2011, 12:21
Yes,
And if you really want to get the set up even closer, you can do the following:
- drill slightly oversized holes and do not tap
- use temporary bolts to hold the bearings, spacer and REAL z-slide in the NUETRAL eccentric position
- weld nuts on back side
- remove and flatten as necessary.
This method will ensure any inconsistencies in the grinding of the vee profile on the z-slide are accounted for in your layout on the spider.
I have had a lot of practice at this....to date, I have manufactured 7 spiders with this method. (I like the practice)
Good luck.
Problem drilling the pinion concentric jwt Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 8 Tue 16 November 2010 07:38
Laser Cut Parts in Washington - Another Order Possible Travish Profiled (laser cut) & bent steel plate 42 Tue 13 April 2010 12:36
Spiderplate error (booboo when drilling) oddname 40. Z-Slide 14 Thu 04 March 2010 13:29
Electronics Order Spreadsheet jhiggins7 70. Control Systems 0 Wed 08 April 2009 07:44
Order of Operations RLH3 Archives 3 Thu 24 April 2008 10:28
