Using steel control box as the heat sink G540
Has anyone tried or does anyone think that bolting the G540 directly to the side of a steel control box with a bit of thermal grease work as a nice big heat sink for the G540?
My control box is a solid steel box 500mm x 400mm x 200mm and weighs 12Kg. Its painted but a quick blip of a sander where I want to mount the G540 would have a nice metal contact for the thermal grease. Reference info http://www.geckodrive.com/upload/G54...Experiment.pdf John |
Do you have the internal mounting plate for your case? I have also considered this option.
I do but I was going to mount the G540 to the sidewall on the hinge side and insert the populated* plate at an angle, feeding the hinge side in first then bringing the rest in and level.
I'll make sure that any high components that would foul the G540 are on the opposite side from the hinge. Hope that makes sense. John *populated as in mounting plate has toroidal transformer, capacitor, rectifier, switches, fuses, etc etc already mounted on to it. |
John, my G540 is mounted exactly like that; as you have probably noticed, it's design encourages that (computer and motor connectors on the outside, power and control signals on the inside), and Gecko even provides you the template for where to cut and drill. I didn't bother with the thermal grease.
As long as you either have no other large heat sources in the box, or you are providing some airflow through the box (computer fan exhaust, filter input hole), it seems fine. |
| Using the Gecko G540 drive a MechMate | stefanv | 701. Motor Drives | 42 | Sat 07 May 2011 03:45 |
| G540 and Meanwell Power Supply For Sale | ranchak | The Market Place | 0 | Sun 10 January 2010 21:11 |
| Motors heat up when power is on | Gato Richy | 702. Power Supplies | 3 | Sat 18 April 2009 22:13 |
| Pre-finished steel rails from Standard Steel Specialty | dmoore | Rails & Rollers | 0 | Thu 01 May 2008 16:28 |
