Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Thu 16 August 2007, 08:04
Metric vs. Imperial plate thickness
Is it possible to use 3/16 steel for parts:
2 off 10 30 455, 4mm or 5/32" thick
1 off 10 40 432, 4mm or 5/32" thick
It seems that some laser cutters I am getting quotes from dont stock 5/32. Also will there be an issue with the locating / welding tabs? Can you grind the tabs to fit if I use the thicker metal or should I redo the tab holes prior to cutting? Do you see any other obstacles that I dont?
Thanks for the help
Domino11
Old Mon 20 August 2007, 09:26
Heath, I tried to answer your question before, but my access problem swallowed the answer.
The 3/16 should be okay except for the tiny bit you need to grind off the tabs. I don't see any other headaches.
Old Mon 20 August 2007, 10:23
Thanks for the reply, Hope you get your problems with the forums resolved. I havent noticed any problems posting for myself yet but will let you know if I do.
Heath.
Old Mon 20 August 2007, 17:43
Gerald if 4mm material for parts 1040432, 1030455 was not available would you choose 1/8" or 3/16". thanks
Old Tue 21 August 2007, 00:03
3/16".
Old Fri 07 September 2007, 08:01
Sorry about another thickness question. but do you think that for part 10 30 422pb (marked 10 20 422pb in the dxf file, did you see this error?) is slated for 2mm or 14 guage material. Could I use 3mm material or 1/8 inch? Would this cause any problems? Thanks
Old Fri 07 September 2007, 09:29
Heath, a 50% increase in plate thickness is drastic and the extra mass is significant. But the machine will run okay.
Old Thu 04 October 2007, 19:15
driller
CAD dimmentions
I have been trying to review the files before I see what getting them cut would cost.
I can not find a simple cross reference to the 300 MPa steel.
Anyone have a more common spec for those of us here in America ?
Dave
Old Thu 04 October 2007, 20:49
Any easy welding mild steel with a minimum yield point of 300 MPa (MegaPascal) [43 511 psi]
