Old Mon 21 June 2010, 04:28
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
For a moment I thought they have send me the wrong thing.
Old Mon 21 June 2010, 04:57
I now see HSS in red on top of the table....that is not a good idea, they get blunt quickly. (High Speed Steel). Better to get "carbide" cutters made from solid tungsten carbide. They look the same.
Old Mon 21 June 2010, 05:00
I was just going to ask what he wants to cut with it. I bought some and they went dull within 2 minutes.
Old Mon 21 June 2010, 05:10
Johan, you might consider getting it from Cape town from Power tool repairs (021-448-2620) ask them for a catalogue about R60 then you can see what you buy.It might be far from you but so far they are the best and just get postnet to pick it up for you takes 2 days at the most.
Old Mon 21 June 2010, 05:34
Jan de Ruyter
Just call me: Jan
Pretoria
www.somta.co.za
Old Mon 21 June 2010, 07:20
Lex
Thanks Hennie, I will check it out.
It will have to be from a supplier like that in the future or Somta as Jan suggested.
Old Mon 21 June 2010, 07:46
Lex
Old Mon 21 June 2010, 07:48
Ok ok we get the message ...
Old Mon 21 June 2010, 10:37
Johan, the guys with the widest range of stockists is Toolquip. Call their Durban number to see if they have a stockist near you.
Old Mon 21 June 2010, 12:30
Does someone has experience with insert tools like Her-Saf ? Would they be ok for particleboard and MDF cutting every day? Inserts seem to be relatively cheap but dont know how much they last.
also while searching the net I found these
http://www.bamcarbide.com/1x2o1cutdi1l.html
What is the experience inserts vs. bits like those?
Inserts can also be found to be of solide carbide tungsten, also what worries me is would the chinese 2.2kW spindle I bought be powerfull enough to plunge and work with 12mm insert cutter.
Thanks for help!
Old Sun 27 June 2010, 09:20
Lex
Just to show you guys what type of sales people I have to deal with in Zululand.
The collet on the right is my existing imperial 1/4" to 1/2".
I ordered a metric one but received another imperial one.
I send it back and then this strange creature arrives. (on the left)
It looks like the imperial collet that they have heat up and pressed around a 6mm shank.
Well, what can I say, it still doesn't work because now the outside just falls out of the Makita chuck.
I can't wait until tommorow (Monday) morning. Man..oh..man!
