Old Sun 09 May 2010, 03:46
liaoh75
Just call me: David
Taibao
Taiwan
Alternatives to Gecko Drive?
I've been looking into building a second machine (possibly more) and considering Motion King Steppers. As I look around in Taiwan, most CNC machines use drivers that accept 220VAC. It is the power supply and controller in one unit for each axis. I don't know if they take the same step and dir signals that Gecko drives use. Does anyone know of anything like this that could possibly be substitute for the Gecko G203V.
I'm not unhappy with my Gecko Drives in any way. Their products are top shelf and I would recommend them to anyone without hesitation. I'm just thinking; if the Motion King Motors are so much cheaper and just about comparable in performance to the much respected OM brand, is there a "Motion King" alternative to the Gecko?
To clarify my intentions, I run a language school in Taiwan and want to start offering a CNC router course for students interested with the entire course taught in English. I want to teach how to build a CNC router from scratch and how to operate it. Earlier on, I asked about a "mini" Mechmate and that is what I've been planning.
I have already purchased a 25 seat license from Vectric for my classroom. Now I'm on the hunt for a cheaper alternative to the Gecko G203V + separate power supply.
Old Sun 09 May 2010, 04:38
isladelobos
Just call me: Ros
Canary Islands
Spain
Ok David.
Two in one, interesting.
As you good say, the quality is directly proportional to the price.
If you want TRUE resolution you get that through gearing/belt reduction/higher TPI. It's pointless to have resolution many times greater than what your mechanics can hold. Errors multiply. IF you have .001 of backlash and have a resolution of .00001 then it adds little to the actual accuracy of the machine.
Old Sun 09 May 2010, 07:30
MotionKing offer drives under their own label.
The most commonly offered Chinese drive is Leadshine, or differently labelled equivalents.
I know little of these drives, but they all appear to be compatible to Mach and EMC in that they will accept step/dir. pulses.
Old Sun 09 May 2010, 08:58
David, a search for "leadshine" on this forum shows up quite a few results - some MM's are already running with them.
Old Sun 09 May 2010, 11:03
liaoh75
Just call me: David
Taibao
Taiwan
Thank you Gerald!
Using the Gecko G540 drive a MechMate stefanv 701. Motor Drives 42 Sat 07 May 2011 03:45
Newbie needs help with figuring out drive configurations (slaved drive for x-axis) ikeike 701. Motor Drives 5 Mon 04 January 2010 21:06
Slaving a motor - put its drive in parallel to another drive on the same BOB output J.R. Hatcher 70. Control Systems 34 Mon 16 November 2009 09:13
Rails are bended...What alternatives I have...??? :( Kobus_Joubert Rails & Rollers 12 Sat 31 January 2009 15:55
How do i wire this which gecko drive to use eloid Archives 1 Mon 05 March 2007 05:07
