Z dropping suddenly - computer response is slower
Hi All,
since yesterday , my Z axis has dropped twice while cutting - this once has spoil a work piece and once killed a 8mm endmill off late I have observed that the computer is responding slowly- may be a virus or may be overheating- but well this is a atom based board and I don't feel so much heat is generated in that now folks can you all let me know if you faced this droping Z axis - and the reasons and solution if you had cleared them- the Mach DRO does not change values. RGDS Irfan |
Dropping Z axes well known on ShopBots. The typical advice over there is:
- check that bit is not sliding out of collet - check grounding/earthing (we had Z problems and cured this way then) It was primarily because of the SB z-drop experience that our MMs got shielded/screened cables from day one. |
Irfan, myne dropped due to a Gecko that died.
I just finished a job which ran for 10 hrs and there was no Z drop- I think it is the 8mm collet which is giving up! and letting the endmill slip!
I had a endmill GROWING longer if I cut to hard...looks like the extra friction causes the collet to slip on the shaft.
An up-cutting bit is pulled down by the cutting forces.
it happened to me, at the begining with my handheld router. I googled and found that collet has to be kept clean, and when you put your bit into the collet, don't put it to the end but about 1/8 of the end of the collet. After applying this technique, no problem. Also, could be, as you said, that collet is giving up. ![]() |
I have had different collets on my router that would just not hold the bit reliably. Find one that works and stay with it. All are not made the same as I found out.
Also look for any heavy cuts or full cutter width's with chatter. This can draw the cutter out of the holder as well. Over torquing of the collet nut will distort the holder, collet and taper of your holder or spindle, causing problems later on...... for a ER 16 collet nut you want to have 45-50 ft/lbs of torque. ER 20 collet nut you want to have 67-75ft/lbs of torque. Hope this may help.
Travis |
#10
The endmill I used is a 4 flute one with slippery shank- may be thats the reason for it to slip. need to be careful while doing this.
#11
Irfan where was the collets manufactured
#12
Irfan, what spindle speed & feed rate are you used with 4 flute end mill? I has great success in burning up carbide 4 flute end milling bits 10 minutes into machining...
#13
Ken,
I remember reading from somewhere that if you have four flute cutter, your spindle RPM must be two times lower - you have two more cutters. I forgot about feed rate. |
#14
Me too.... burning some end-mills on first try, that is why I cut with my cheap Pro-Tech cutters.
#15
Well
you folks can just say that Irfan was in a hurry! ![]() |
| Computer desk - glueless | javeria | The Show Room | 13 | Wed 12 September 2018 21:05 |
| Keeping dust out of the computer | vadeem | 80. Computer Hardware & Software | 14 | Sat 24 August 2013 07:48 |
| Great computer shop cabinet - "Mobile Security Lcd Computer Cabinet Blue" | WTI | 80. Computer Hardware & Software | 5 | Thu 29 July 2010 03:33 |
| New registrations suddenly increased | Gerald D | Archives | 24 | Fri 09 January 2009 11:58 |
| I'm nearly finished (computer simulation) | Euan Stewart | Construction started, but not cutting yet | 4 | Wed 20 June 2007 21:08 |
