Old Tue 13 April 2010, 17:28
shelbygt500buddy
Just call me: kyle
stuart fl
Spur Gear decision
Hi, I have 640oz (+,-) with a 4:1 gear ration on top of that.
Going to purchace the stdsteel gear rack 20/20 (or w.e it is i dont have the info right in front of me.
But i was wondering which spur gear should i go for
A 20 or 24 tooth gear. there is also a 32 tooth but i would rather smoother then faster. What do you all suggest?
Old Wed 14 April 2010, 01:27
For smoother, rather than faster, the 20 tooth would be the choice in the inch based diametral pitch system (DP 20).
Old Wed 14 April 2010, 05:46
shelbygt500buddy
Just call me: kyle
stuart fl
Thank you Gerald you are fast at replying and always a help. I also had a question. Is there a formula to estimate accuracy? I saw the resolution but thats not necessarily accuracy or is it?
Moore Gear Racks jessyjames The Market Place 2 Mon 15 March 2010 22:32
Pinion gear chatter lunaj76 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Tue 27 October 2009 01:29
Inconsistent accuracy - loose pinion gear bfauska Troubleshooting 11 Sat 05 September 2009 09:05
Z axis gear reduction Art 40. Z-Slide 0 Mon 10 March 2008 19:01
Why must the gear teeth be so small or fine? driller Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 15 Wed 27 February 2008 21:56
