Belt or Rack
Hello everyone
I am in the process of manufacture of my machine and I have a question about what kind of system I use for Transmit motion, the general specifications of my machine would be: axis x 183 cm axis and 244 cm z-axis 30 cm I already have the engines MotionKing ref 23H8603, the idea is to make the transmittance of motion directly, but because of the cost it would involve using the rack and pinion system intended to use timing belt and pulley. Do not know if this is the better or for this size of machine is only recommended the use of rack and pinion. If i can use pulley and timing belt which would be the appropriate size? Thanks Gustavo Osorio |
Gustavo,
your engines look awefully small for the mechmate, what made you decide to buy these small engines? The Mechmate is designed around rack+ pinion with a nema 34 size engine With your type of motor you need to use a timing belt, 1:3.6 is a favorite here, See also this post and this answer. Here is a link about selecting motors: Ries Last edited by riesvantwisk; Tue 16 February 2010 at 19:22.. Reason: Added links to selecting motors.. |
If you are looking at building your own design router, you might want to check out www.cnczone.com. They cater to that kind of thing.
| Added belt transmissions #16 - Demotte, IN | myozman | MechMates already cutting | 62 | Tue 12 January 2010 05:46 |
| Toothed, Timing Belt Suppliers | Victorian Signs | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 5 | Sun 16 August 2009 01:03 |
| Off the shelf belt drive? | myozman | Motors & their mountings | 2 | Mon 22 June 2009 20:41 |
| Belt-driven spindles | javeria | 50. Toolheads | 6 | Wed 03 December 2008 07:01 |
| Replace rack with belt? | LK LLoyd | Archives | 5 | Wed 17 October 2007 14:23 |
