#271
Looks very nice!
But..... are these holes not to big for the mosquitos?? ![]() Sorry, I couldn't resist.... Ries |
#272
some more pics of the finished inlay work - the person finishing the piece filled the v groove with white metal putty - the lettering looked fabulous now - tomorrow its gonna get polished!
#273
Irfan,
Is that a triditional design that you used or one you came up with? |
#274
Irfan, I am interested to know exactly what ' white metal putty ' is. Any trade name or website that describe it. Will it not shrink and fall out later ?
#275
I think the white metal putty is talc mixed with GP resin,
nils thats a traditional design - art work is available over the internet |
#276
Irfan,
Doesn't putty shrink when dry ? I am asking becoz I am using other material sometimes there is gap, which can be filled with putty or putty may be used as inlay material. Nice work. Last edited by DMS; Sun 27 December 2009 at 10:39.. |
#277
Actually sharma - I don't know much about why he opted for that - I am aware of the fact that putty shrinks, btw what material do you use?
#278
I was trying to upload images when you replied.
I use bone pieces, supplied to me in sheet form glued on board. Which is then cut as inlay material. see example. |
#279
one more jali work
#280
Nice Irfan, just to think a couple of years ago we used a fret saw to do those cutouts.Kobus I use a two part epoxy to do those type of fillings,if i work with valchromat I mix some of the dust with the epoxy and once it dries out and it is sealed you can`t notice that it is epoxy and it doesn`t shrinks ( the liquid type )
#281
Problems in 2d cuts
Does anyone know why I am getting this sort of cuts?
I upgraded my Z with linear slides and yet face this problem?? it is solved to a large extent - but is it the curves in the artwork, or do I need to use a different post processor, or is it that I need to convert the curves to some sort of continuous curves??? or do i need a different Mach setting??? please help me. RGDS Irfan |
#282
Not too sure what is going on there. I seemed to have that problem at one time but it slips my memory.
What software are you using? Sometimes when I import stuff from Autocad into Aspire, Autocad will creat a bunch of little nodes around curves. I then have to have Aspire smooth the curves with one of its features.. But I think your problem lies in Mach if that is what you are using. All your curves lines are just too symmetrical to be a hardware problem, at least that is what I see. Seems like you need to check your "CV" settings in mach. I will keep on thinking about what might be the prob. James |
#283
May be CV setting in mach - i am thinking of same thing James, what is your CV setting?
I am using Artcam, what utility do you use in Aspire for curve fixing? yes the curve was imported from Acad. |
#284
Irfan, I had the same thing on the little disks that I did recently.It also baffeled me I eventually enlarged the drawing on the screen of my dxf file and saw that it was actually the drawing itself that had those ridges on them, it is not your MM that is the problem but the actual vectors that the toolpath follows.Enlarge that same drawing a couple of times where it gives you the rough cut and see if it is that.
#285
Thanks Hennie - i will look into it soon
#286
I noticed this sometimes when using a 12mm straight cutter and pushing it to cut 2mm per pass at a high feedrate. My whole table starts to vibrate and it seems that the router on the z-slide starts to oscillate. When I slow things down and take a 1 to 1.5mm deep cut it dissapears.
#287
Irfan, did you notice that the rough cut is only when the X and Y motors run together to make a curve? If so, then see Rough Cut on Diagonal
#288
Can you please post a pic of your settings for Mach3, I like to see how your CV settings are.
#289
Irfan,
Try to spline vectors and delete extra nodes. |
#290
one more of the Jali's
#291
Nice Work Buddy, keep going..............
#292
I think I need to visit India...looks like you have some nice wood available. Nice going
#293
Irfan, Very Very Nice.
![]() Last edited by domino11; Tue 12 January 2010 at 15:35.. |
#294
As always , very good work. Keep them coming I really enjoy looking at them.
#295
Ah Kobus, thats pieces of teak wood joined together to form a plank -
heath - vishnu and Leo - thanks for the good words ! |
#296
I like it when you do those jobs, make me want to make some doors with them
good work Irfan.We need to win the lotto to afford teak in SA. |
#297
Nice work Irfan. Did you find the reason for the rough cuts you mentioned with the earlier pictures?
#298
G' I seem to have not set my machine upto the mark - i need to look into it further,
meanwhile does anyone have the model 99474(running horse) from 3d model club, it was given out last year as a free sample, the one I have has a corrupted zip file |
#299
show us a example if you can
#300
![]() this one oops its 99473 |
| Wood carving - Bangalore, India | issac winfred | Introduce yourself and start planning | 3 | Wed 12 August 2009 10:13 |
| We made it to #3 !! | WTI | Archives | 3 | Thu 05 June 2008 15:57 |
| Laser kits for India - out of Bangalore | javeria | Profiled (laser cut) & bent steel plate | 3 | Tue 13 May 2008 22:50 |
| CNC Router with Servo motors & belt drives (non-MechMate) - Bangalore, India | Irfanulla | Archives | 67 | Mon 01 October 2007 13:11 |
| Hi, new to the gang - Bangalore, India | ANIL | Introduce yourself and start planning | 5 | Sat 09 June 2007 10:45 |
