#511
I do the same with those cheap YELLOW cutters. Find they work and work and work
#512
Jip , Marius. Kobus since I discovered that nice shop in Cape town I don`t buy the yellow ones,I needed a quick fix and those were the only one`s I had so they did what I needed them to do.
#513
Hennie, tell more about the nice shop. We have Leitz tools over here that I discovered recently. They order Onsud cutters if they don't have them stock.
#514
What are their prices like Marius ? Would they have 3mm or smalle ballnose cutters as well ?
#515
Made in Pietermaritzburg: http://www.somta.co.za/cat/03m.htm. Suggest you contact them to find out about stock/pricing.
#516
Thanks Gerald, but their range has a 3mm ballnose only with 3mm shank. I did find one with a 3mm ballnose and 6mm shank, but paid R275.00 for it.
Will check with Somta on price on those 3mm shanks and then try your trick with the 6mm round bar with a 3mm hole someday. |
#517
Kobus, I had to use dremel cutters this week.I took a old 12 mm 2 flute cutter that hit a g-clamp and drilled a 3.2 mm hole to fit the cutter with a grub screw to tighten it.Made sure that when the grub screw was tightened it was flat with the dia of the cutter so when it is in the collet it can`t come lose.That way the dremmel cutter went into the hole as deep as it can so there is no movement on the 3.2 cutter when it cuts into the material.I am going to Sedgefield today then I will get it from the workshop and post a pic of it.It is one of those boere manier items that work.Marius the shop is Power tool repairs in Cape Town don`t have the number with me now. they do Dimar bits,I got a catalogue of the cutters,saw blades everything that one might use to cut with.
#518
Dimar, of Israel, lists Power Tool Repairs as their distributor here:
http://www.dimar.co.il/Distributers.asp |
#519
Kobus, The website is down until 21/12 for maintenance, but look at the catalogs over here http://www.onsrud.com . The guys at Leitz will order for you if they dont have in stock and the pricing is reasonable. Most the tools are solid carbite.
I made a ring from 30mm MDF with a slot cut through on one side to fit my dremmel into the clamp that holds the router. I use this to engrave labels. The dremmel has a very small (2mm) V cutter that I use. |
#520
I received a quote from Power Tool Repairs in Cape Town, and I asked them to post it to me and let me know the cost of postage. Everytime I communicate with them they don't add the postage. I get the impression this chap want me to pick up from his shop and don't want to be bothered with making up parcels.
I have used Dremel bits as well, putting the dremel collet into my makita 6mm collet, but when it stresses a bit the dremel collet tends to break....they are very flimsy. |
#521
Kobus,
I fit the whole Dremmel machine to the router. They are meant for smaller jobs though. I engrave the Rowmark material with this setup. |
#522
Something like this http://mechmate.com/forums/showthread.php?t=879
#523
Kobus let your local postnet send a courier pick it up the same day next day at 12 it should be in Brakpan ( Berco express).Here is that cutter
#524
Ok Hennie don't be so slow man, make me one or two of those things please. 6mm O/D and 3mm I/D. Wish I had a lathe....Groetnis
#525
Are you going to use the dremel bits?if so arn`t they all 3.2 mm dia. 6MM o/d is a bit to thin to put a grub screw in.What is the max size of your collet 6mm ,8 mm, 12 mm.
#526
Yes you are right again...3.2mm
I have 1/4 inch (6.35mm) a 6mm and 8mm collets on the little Makita. So maybe a 8mm O/D will be better. I will send you a piece of 8mm round bar or do you prefer rebar.... ![]() Or if you can SPLIT the 6 mm length wise so that the big collet clamp the insert. |
#527
I will use the 8 mm keep your bar I will make a plan.
#528
Baie baie dankie....moet ek hulle kom haal ?
#529
Laat daai bakkie se neus Kaap toe wys,laat weet net wanneer.Gerald gaan julle nog diekant toe kom?
#530
Ons ry oormôre.
#531
I just jump on the bike and leave the baggage at home...
#532
Sal nice wees om julle almal te sien
#533
Jy lees nie reg nie..ek los die ou sak en kom alleen....grappie....nee gooi dit sommer in die pos asb.
#534
Ek het reg gelees,ek doen dit army style ek hou net my mond
is more by die werk winkel dan sal ek gou `n plan maak. |
#535
Just updated my V-Carve Pro V5 to the latest FREE upgrage. Wow I am impressed.....now to explain to the wife that I need that extra stepper and Gecko.... life is tough, but a man has to do what a man has to do.
Flute.JPG Spiral.JPG |
#536
Getting there. Progress on the bosses round table. Run out of my favourite waterbased varnish, but will give the legs some more once I receive the varnish....My local hardware has promised me for 2 day's now, but still no varnish. The boss is now putting on the little granite pieces into the 4 clovers. Thinking of some dark colour grouting between the pieces to go with the leaves on the border.
I am happy with the way that old BBB cut out the legs....slot into each half, one from the top and the other from the bottom...slid together like a glove. Had some issues with the legs breaking, so I sandwitched them with 4mm plywood. They will not break that I promise you. DSC00944.JPG DSC00945.JPG The next table will be from proper wood...something like Kiaat.. Last edited by Kobus_Joubert; Tue 22 December 2009 at 08:04.. |
#537
My late dad was a carpenter / cabinet maker, but sadly he died when I was very young and I did not have the time to learn the tricks of the trade from him. I play around with making stuff for myself, but is not a good cabinet maker. I battle to make nice tight connections on the joints. I think the biggest problem is that I battle to sharpen my chissel properly...
![]() So I decided that old BBB must help in this regard...and since I am at home with some spare time it was time to play. Made a jig that will hold the pieces with reference to a ZERO point on the same piece of MDF. Did the first cut, but it did not fit so well. Speed was set too high. Adjusted some settings and must say I am please with the result. Will try another type of joint later. DSC00951.JPG DSC00952.JPG DSC00954.JPG |
#538
Kobus,
Nice joint. Which bit did you use to make it? |
#539
3mm straight cutter. Too short to go right through...will look for a LONG 3mm or 6mm sometime next year.
#540
Kobus,
I like the way you have it now. It would make a strong joint. |
| #11 Has died a fiery death– Cape Town (S. Africa) | Alan_c | MechMates already cutting | 556 | Tue 10 August 2021 21:54 |
| Tables of all kinds | Kobus_Joubert | The Show Room | 17 | Fri 04 May 2012 08:33 |
| On to parts Ordering - Matthews NC USA | qroger | Construction started, but not cutting yet | 51 | Mon 11 October 2010 05:07 |
| One system controlling two tables? | Mountaincraft | 701. Motor Drives | 4 | Fri 10 September 2010 18:27 |
| Ordering parts: Marysville, CA-USA | MachineMonkey | Construction started, but not cutting yet | 7 | Fri 13 March 2009 18:45 |
