Old Fri 25 September 2009, 09:14
Me and Vishnu both have the VFD022B21 A on our Mechmate's running single phase - no problems whatsoever! so go ahead with confidence
Old Fri 25 September 2009, 21:53
Originally Posted by BartDeckers View Post
I have a 3 fase 230 Volt net at home
Bart, if you live in Europe, your 3-phase is about 380 Volt if measured Live to Live (Δ) and 230 Volt if measured Live to Neutral (Y). The typical VFD is for Δ connection only and allows the connection of 3 Live wires (no Neutral).
Please check with the supplier, but I believe you will not be able to use that VFD for a standard 3-phase situation in Europe.
Old Sat 26 September 2009, 04:34
BartDeckers
Just call me: Bart_D
Antwerpen
Belgium
Thanks to everyone for the info on the connection of the frequency drive. Glad to hear that Irfan and Vishnu are using this setup without problems.
You are right about the supply net in Europe. In Belgium 1 fase 230 Volt is common for domestic use and 3 fase 400 Volt for industrial use.
At home I have however an old net of 3 fase 127Volt/230Volt so I have 127 volt between neutral and fase and 230 Volt between the fases. This is not very common but it still exists in some areas.
Setting up a Huanyang HY02D223B VFD Jayson 701. Motor Drives 20 Fri 02 November 2018 07:25
VFD wiring - right or wrong javeria 60. Wiring & Cable Management 12 Tue 27 July 2010 20:41
Lurching at Reset - interference from spindle VFD waynec Troubleshooting 12 Thu 05 February 2009 17:00
Wiring the VFD and Spindle waynec 50. Toolheads 4 Thu 18 September 2008 23:09
