Old Fri 07 August 2009, 00:15
Customized Gas Spring
Found a local vendor who can supply customised gaspring in small quantity. as small as 1 unit. :-)
He is quoting me US$40 a pop
with choice of mounting as well
Now, what will be the dream physical dimension and spec of this gas spring?
I am be willing to organise a group buy for the benifit of fellow MM builders.
Old Fri 07 August 2009, 01:07
Attached is the .rar of the gas spring dimension form,
the vendor wrote me this,
Hi Ken,
You can delete those data in the from and fill in yours....we left those data there so that you can have an idea what info we need to build the gas spring for you.
If you need other mounting type(eg L-plate), kindly speficy details.
Old Fri 07 August 2009, 04:13
Ken, that spreadsheet doesn't read nicely at all.
Old Fri 07 August 2009, 06:49
OK,
I'll try to redraw what I understand from it.
Ken
Old Fri 07 August 2009, 07:59
I am interested to see;
- the major outside diameter (max of 22mm will fit)
- the diam and length of the threads at the ends (I presume both male ends)
- lengths measured from the shoulders of those threads
Regarding the charge pressure, realise that some guys use heavy spindles, others light routers, so there won't be one specification for everybody.
The price of $40 is not attractive - we also have them made to spec in Cape Town (also one at a time) and the price is about $12 - $15 each
Old Fri 07 August 2009, 11:03
Thanks for the heads up Gerald.
Anyhow, this is the last component on my shopping list which I hope to find a local supplier, at least I know where to buy an expensive gas spring now.
Old Fri 07 August 2009, 12:05
Ken, our gas spring suppliers are linked to auto spare parts shops. These springs are common on tailgates (the big folding up doors) on the back of hatchback cars and small trucks/busses. The spares shops keep some uncharged ones in stock and then charge with nitrogen gas to a specific load (kilogram) requirement. The charging device is ridiculously simple (and cheap). I think you could find less expensive springs if you shop around some more.
Old Fri 07 August 2009, 22:42
I guess I didn't look hard enough.
thanks for the lead.
Gas Spring for 350mm YRD 40. Z-Slide 6 Thu 28 October 2010 04:49
Modifying a gas spring to make it pump-able hans.arnell 40. Z-Slide 8 Sun 04 January 2009 07:51
Gas Spring : Compatible automotive gas spring Nikonauts 40. Z-Slide 0 Sat 03 January 2009 09:59
Multiple gas springs for extended stroke sprayhead 40. Z-Slide 12 Fri 12 December 2008 07:26
Mamba 6-Roller Z Slide with a gas spring not fully retracting...due to build mistakes dmoore Archives 8 Thu 05 June 2008 14:38
