Old Fri 08 May 2009, 17:41
Rad Racer
Just call me: Wayne #25
Minnesota
Lowcost - 3ph spindle
My current project is a lowcost "brushless" spindle. Here's a teaser photo of the prototype
Don't know how well this will work.....hope to complete and test the prototype this weekend
Spindle spec's:
2000watts (~2.5hp)
10,000rpm
ER-16 collet
Old Fri 08 May 2009, 22:56
VERY interesting stuff!
Old Mon 18 May 2009, 22:20
Rad Racer
Minnesota
Prototype 3ph spindle is complete
I finished my prototype 3ph spindle. Here you see I have it mounted on my little cnc for the first test run.
Currently uploading a Youtube video.....I will post the link once it is complete.
If this all works out well, I plan to purchase a Sherline spindle built for ER16 collets. This will allow me to use bits up to 3/16" dia.
Old Mon 18 May 2009, 23:36
Rad Racer
Minnesota
http://www.youtube.com/watch?v=fPLdHeRQp_w
Here is the Youtube video link.
Old Tue 19 May 2009, 04:24
Isn’t it beautifully what a can achieve with proper mindset!!
Nice going Wayne, Robert
Old Tue 19 May 2009, 09:20
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Awesome!
What's your target budget, do you think cooling will be adequate, and do you anticipate the ability to control speed through g-code?
Old Tue 19 May 2009, 13:36
Rad Racer
Minnesota
Jeff,
The items required to build this spindle cost about $400. Cheaper motors and controllers exist, but I prefer to spend a little extra and be sure of the quality.
The finished project will use an industral Sherline spindle....they are good for 10,000 rpm continous. www.sherlineipd.com/spindles.htm
The motor and controller will require cooling, a simple muffin fan will do the trick.
I believe speed control through Mach3 is possible, but will require PWM frequency conversion. Mach3 produces a base PWM freq of about 5-10hz. a typical RC speed controller operates with a 10x higher base freq (50hz). I am sure a simple microcontroller w/some code will solve the problem....but like everything else it takes a little time and thought to get it to work. For now, I will use a little timer circuit to drive the speed controller...simple and cheap
Old Tue 19 May 2009, 14:51
Wayne,
Wow that looks impressive, have any video of it cutting stuff yet?
Old Tue 19 May 2009, 19:09
Rad Racer
Minnesota
No cutting video yet....need to mount it to the Mechmate first.
Old Sun 05 July 2009, 08:56
Rad Racer
Minnesota
Project update. I was not happy with the power output of the motor spindle combo....thought it would be more powerful at the low end. I will probably just breakdown and purchase a factory spindle
