Old Fri 07 November 2008, 09:30
gmessler
Just call me: Greg #15
Chicago IL
Problems with square washers (also called taper or bevel washers)
When I got the washers I found that they fit great on the large channel but they were a little long for the 3" channel so I had to trim the small end a little.
Old Fri 14 November 2008, 21:04
Thanks for the pics Greg.
It would also help if the holes in the small channels were drilled slightly off-center, towards the lip. Also if a smaller bolt and washer was used for this joint.
Suggest that folk first buy washers to match the small channels and then drill accordingly.
Old Fri 14 November 2008, 22:02
gmessler
Chicago IL
Glad to be of help Gerald
Looks like I'm rapidly becoming the poster child for how not to build a MM.
Old Fri 14 November 2008, 22:42
If it works at the end, you built it right!
It is a common thing to drill in the center of the outside face of angle and channel iron. Folk must consider that the inside face is off-center, and rather drill according to the center of the inside face.
Also, that inside face is flat for only a short distance - then you get the round fillet in the corner. I guess that the biggest washer that seats properly inside a 1.5" wide channel is a 1" square washer - that only has a 3/8" hole intended for 5/16" screws. (McMaster 91151A030) Guess I would drill them for 1/2" screws . . . .
Old Sat 15 November 2008, 23:10
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Standard Back Marks
This should be a good guide to drill holes through steel sections. We used it as a standard for manufacturing of structural steel
Old Sat 15 November 2008, 23:20
That's from your little blue book isn't it I forgot that the info is in there
Note the max. recommended hole size in a 1.5" wide channel = 8mm [5/16"]. That's probably why I prefer to weld those joints.
Old Sat 15 November 2008, 23:35
Lex
Yes it is.
The small sections are very critical on this sizes. I few times I used non standard back marks and every time we had either washer or spanner clearance problems. Always the talk of the week when this happend. "The draugthsman stuffed up again!"
Old Sun 16 November 2008, 05:12
I forgot about the spanner/wrench clearances - they are of course very important as well.
For fixing the wooden table surface to the cross-support channels, I envisaged that we do not bother with the square washers because the loads are so low (tightening wood to steel).
