Old Mon 09 June 2014, 08:12
Tokamak
Just call me: John #121
Monrovia (ca)
Started getting things wired with the transformer. Then on to the input of the Geckos. Then the latching circuit with 24V E-Stop.
Before I could power up I needed to change one of my welder outlets from 250V to 250V/125V. My Controller needs a neutral for the 125V stuff.
Disconnected the Power Supply output to protect the Geckos while I played with the Power On latch and E-Stop circuit.
Power On latch and 24V E-Stop circuit worked. Measured the no load voltage at the output of the Power Supply (48.4V)
Old Mon 09 June 2014, 08:25
Tokamak
Monrovia (ca)
Took a break from wiring back to motor mounting.
Cut some Teflon washers. 1/16"(1.6mm) and 1/18" (3.2mm) thick.
Holding the bolts in place with Push Nuts. Cut flats on the end for tightening the lock nut.
Old Mon 09 June 2014, 10:00
dbinokc
Just call me: DB #118
Oklahoma
Like the push nut idea. I will have to use that on my machine.
Old Mon 09 June 2014, 10:04
I put a dab of epoxy on the countersink area and had the slot cut in end of bolt.
All great solutions shown here to make it a bit easier for that low clearance bolt requirement.
Old Tue 10 June 2014, 07:38
Tokamak
Monrovia (ca)
Installed the X-Motors
Mounted the X-Motors and was able connect one to a terminal board.
Old Tue 10 June 2014, 11:41
did you really weld your stepper hole shut to avoid the standard 'put a sticker on your hole' comment ? DRASTIC dude
That looks like a split ring on second guess, so i guess they are supplied that way by the factory (the picture was not too big)
Ps. good progress. I am connecting my motors with a Neutrik plug, other then that ... very similar build (stage) !
Old Tue 10 June 2014, 13:32
Tokamak
Monrovia (ca)
Factory supplied.
I wanted to use a plug and socket but had the terminals available. Nothing dangling. The yellow cable will pass thru a square EMI suppressor. I'll mount the square suppressor and use it as a cable support for that side.
See figure C
http://www.mouser.com/catalog/catalogusd/646/1184.pdf
Old Tue 10 June 2014, 23:44
I hide all connections inside a junction box where the E-stop is mounted.
Looks nicer too.
Old Wed 11 June 2014, 08:03
Tokamak
Monrovia (ca)
Ken,
Good thought, I may wait until I mount the E-Stop Boxes before I finish terminating the motor wires. I also need to install relays for the proximity sensors in the E-Stop box.
Trimmed the spindle mounts and plan on cutting the ears down and counter boring for 1/4-20 socket head screws closer in.
Old Wed 11 June 2014, 10:00
Better to not use relays for prox sensors.
It will work but they have 'random' delays, making it less accurate.
Use a simple optocoupler (4N27 for instance), and a resistor instead.
Old Thu 12 June 2014, 06:06
alan254
Just call me: Al #95
mystic ct
Like the idea of an optical connector. I have been using a Winford RLP104 relay panel mounted in the y car for over two years now with no trouble at all.
Just information.
Al
Old Thu 12 June 2014, 10:07
For the record, relays will not cause any problems if you choose to use them, many have... They will work. But ... if you are after repetability, they are not as reliable/accurate as optocouplers ( the moment off switching is randomly delayed ( but we are talking miliseconds here ). And optocouplers really divide both circuits in terms of power, so they are 100% failproof isolation, relays not.
An optocoupler cost mere cents, so it's actually even cheaper.
John, you can built this on a piece of pcd for less then a dollar.
I added an 3mm led on the board (between the sensor and the resistor) to have a indicator ( my prox also have an intergrated led but these are buried inside the machine)
It's very simply.
Use the 24 volt specs (since you already have 24 volt e-stop), and choose the circuit that matches your sensor (PNP or NPN)
If you want you can also buy optocouplers with more inputs and outputs os you only need one opto coupler. I choose seperate optocouplers (cuase they are deadcheap) and mounted the optocouplers in feet, so they are easily replaced if I blow them by accident, but this is not likely so hardly neccesary.
Old Thu 12 June 2014, 11:08
Tokamak
Monrovia (ca)
Fox,
When I saw that the opto chip wanted 1.5 volts I went looking for solid state relays and found these.
Input 3-32V DC Output 4A 200V DC 4 Pin PCB Solid State Relay HHG1D-0/032F-20
Now that I see the resistor is figured out for me and they can be so small I may switch back.
Old Thu 12 June 2014, 13:57
Tokamak
Monrovia (ca)
Fox,
Just to make sure I'm clear on this.
Nothing connected to pins 3 and 6 on the 4n27.
Wire the collectors (pin 5) of the 4N427 together and connect to the limit on Bob.
Current limiting resistor on the input (pin 1)
Pin 2 returns to the proximity switch. - correction
Pin 4 connects to ground on Bob. - correction
Old Thu 12 June 2014, 19:05
racedirector
Just call me: Bruce #122
New South Wales
Fox, very interesting, thanks for the circuits. Just a question. ... what would it look like connecting the opto's in series for connection to 1 pin in the bob?
Old Fri 13 June 2014, 08:56
It should also be shown that it can be wired this way for a regular switch
Old Fri 13 June 2014, 09:15
4N27 diagram from datasheet
Old Fri 13 June 2014, 11:18
Fox,
1)Nothing connected to pins 3 and 6 on the 4n27.
Pin 2 connects to ground on Bob.
Pin 4 returns to proximity switch
1)pin3 (NC) and PIN6(BASE) can be left floating indeed.
The rest -> combine image below of the pinout with description and my first image above, and you should be able to do the 'math' (compare the images) so resistor to leg 1 etc etc. ;-)
I have separate inputs for my proxy so will wire all separate.
If you have one input, you can combine them wired in series. You want o have your X1 and X2 wired seperately to be able to autosquare your gantry for example.
Kids words:
The proxi needs power to function, and it put's out a signal that switches on the led inside the optocoupler, which in turn triggers the output side of the optocoupler to switch.
An optocoupler is nothing more then you pushing on the button of your flashlight so you can send a signal with the flashlight to your neigbour, who then pushes a button for you, that opens your gate.
That button he pushed can actually be used to control anything low voltage (like your bob inputs) directly, and your bob can use it to communicate with the software which can control big things.
And because you never had to put an extension cord to your neighbour, to signal him, you can't electrocute him, which is nice, cause he's you neighbor, and you might need him in the future....
In other words .... that lame ass 2 dollar flashlight you built, saves you from from frying your expensive BOB by accident.
Ps1. I use Eding CPU5b, which switches to ground and has multiple limit inputs.
ps2. all images just sourced from the WWW, not my work, but checked to be correct.
Old Fri 13 June 2014, 18:52
Tokamak
Monrovia (ca)
Edit to post #194
Old Mon 16 June 2014, 08:20
Tokamak
Monrovia (ca)
Inching along. Details are getting in the way of progress.
Installed the Z and Y motors. Needed to extend the flats on the pinion shafts of all motors to line up with the set screws.
Painted and assembled the E-Stop boxes.
Received the Solid State Relays (SSRs) from Amazon for the Proximity sensors. The 4N27 chips will be here by the end of the week as an alternate.
Pulled out the computer and installed 60 windows updates, dual parallel printer board, Mach3 and V-Carve Pro software.
Plugged in the Bob with power to make sure that the computer could see the status.
Need to complete wiring from the motors to the Geckos before I can continue with software testing. Still need to get a bearing for the Y Car Idler. I'll see if the local HW store has one on the way home tonight.
Old Mon 16 June 2014, 08:29
Tokamak
Monrovia (ca)
To get 3 switches in the control box I needed to cut the corners off the switch release tabs
Old Mon 16 June 2014, 09:54
All grounds should be connected together. In other words, don't isolate one power supply from another.
Solid State Relays require a minimum load to work properly. If the load is too light, they will not reliably change state. Also, SSRs have a leakage current. You can get a good shock even when the circuit is "off". If you use a SSR to control a DC load, be sure to use a shunt diode to protect the relay. Most AC SSRs switch at 0 volts, which reduces electrical interference. Relays don't have that feature.
Old Tue 17 June 2014, 08:01
Tokamak
Monrovia (ca)
Mike,
I received my 4N27's last night and will probably (based on your comments)go that way instead of the SSR's. Have not found a lot of detail in this area on the forum. It can be tough to dredge out specific information. I agree with the comment Fox made about repeatability of mechanical relays vs electronic devices. Your insight on SSR's is making me lean toward the 4N27 Opto Isolator. If all else fails to work I can always go back to relays.
John
Old Tue 17 June 2014, 08:14
Tokamak
Monrovia (ca)
Along with the 4N27 I received the stepper cable Noise Suppressors (ferrites).
Back to the Spindle clamp modifications. Was able to drill, tap and install 1/4-20 inserts closer into the body of the clamp. Next will be to trim the ears off and the old clamping holes.
Reading about BOB and Mach3 interface for Pause and Resume functions.
Old Tue 17 June 2014, 14:52
Dude, you could have made it from a raw block of alu by now !
Just kidding, nice work, as usual.
Old Tue 17 June 2014, 15:04
Ferrites are made to a certain spectrum and range, you may find you need others to tune out any EMI you may experience. Just keep that in mind.
Old Tue 17 June 2014, 16:51
Tokamak
Monrovia (ca)
Fox,
I think of that every time I cut these. But they only cost me $8 each.
Pete,
I picked up the broadband material since most of the noise will be in the mid range above 10mHz and below 500mHz. Probably won't know the difference.
Old Wed 18 June 2014, 07:09
A 4N27 can sink very little current. It's rated at about 30% efficiency, which means that if you size the resistor on the diode side to allow 10mA to pass, the transistor side will only sink about 3mA. Usually the 4N27 is connected to other logic, either TTL (such as a 7408 AND device) or a microcontroller. If you use other logic, you can can easily create the necessary logic so that multiple opto-couplers interface to a single input signal.
Old Wed 18 June 2014, 07:57
Tokamak
Monrovia (ca)
I keep picturing something like this.
Old Thu 19 June 2014, 10:00
Here's a schematic that shows the use of opto-couplers that have PNP (sourcing) inputs. The 7408 chip shows how I would connect the 4N27's outputs. Each output goes to a single input. On the 7408, if any input is pulled LOW, the output is low. (Edited: It looks like I forgot to connect pin 4 of the bottom 4N27 to ground. The circuit will not work unless that pin is connected to ground.)
