Old Sun 09 June 2013, 10:45
shelbygt500buddy
Just call me: kyle
stuart fl
Help with What I have already installed
Hi,
I believe I made a big mistake. I wired the motors with 18/4 non sheilded cable. I believe i needed sheilded cable now that I look back. Should I finish with what i got and then try running the machine and see if it causing problems or should i rewire all the motors and pull the 16/4 sheilded continuous flex wire? I did the load calcs and 18 gauge for the longest length I have has close to 3% drop or a little more can't remember but was uncomfortable with it.
Old Sun 09 June 2013, 21:08
If it's already wired, give it a try. Electrical noise is unpredictable. If your unshielded wiring is not acting as an antenna for critical circuits, you may not have a problem. Just pay very close attention to anything unexpected. (I've run a single motor on a 25-length of unshielded cable with perfect results. The reason that using shielded cable is highly recommended, is that it's easier to keep a problem from happening than finding and fixing a problem - but if it's ready to run, give it a try.)
Old Mon 10 June 2013, 06:20
shelbygt500buddy
Just call me: kyle
stuart fl
Thank you for the quick response. Everything is shielded inside the control box behind the transformer capacitor and rectfier. So all data from breakout to drivers and drivers to external terminal block for the motors. And power from driver to psu and breakout to power all sheilded
Old Mon 10 June 2013, 17:28
Did you use motion wire?
Old Tue 11 June 2013, 16:18
shelbygt500buddy
Just call me: kyle
stuart fl
Yes, made for continuos motion
Grills Finished and Installed sailfl The Show Room 13 Mon 14 December 2009 23:33
Belt reduction installed, cutting metals - Big Lake, MN chopper MechMates already cutting 61 Mon 23 November 2009 23:02
