Old Sun 16 August 2009, 20:05
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
surfacing a table in EMC
For those of you who have surfaced your table using EMC, do you have any g code you could share?
I tried using the following which was generated by a script made by Switcher on CNCzone.
Code:
G90
Z0.25 F100.0
X0.0 Y0.0 F100.0
Z-0.12 F25.0
G91 F50.0
X99
Y0.625
X-99
Y0.625
X99
Y0.625
.... repeat the last two lines 77 times
EMC didn't like it.
Old Sun 16 August 2009, 23:06
Jayson
Just call me: Jayson #18
Horsham
Hi Jeff,
when I faced my table I used the generator located at the following link
http://wiki.linuxcnc.org/cgi-bin/emc...ode_Generators
Scroll down until you find "facing Software"
Worked a treat for me.
Jayson.
Old Mon 17 August 2009, 00:24
lumberjack_jeff
Montesano, WA
Thank you so much for this Jayson! What a cool link!
Old Mon 31 August 2009, 21:27
lumberjack_jeff
Montesano, WA
FWIW, a variant of this code
Code:
G17
#1=0 (X1)
#2=0.375 (Y1)
#3=98 (X2)
#4=49.125 (finished Y area minus cutter radius)
#5=0
G0 Z [0.5]
G0 X #1 Y [#2 + #5]
G1 X #1 Y [#2 + #5] Z0 F150 (set up feed)
O101 WHILE [#5 LT [#4-#2]]
G1 X #3 Y [#2 + #5] Z0
G0 Z [0.5]
#5 = [#5 + .65] (increments for the next reverse cut)
G0 Y [#2 + #5]
G1 Z0
G1 X #1
G0 z [0.5]
#5 = [#5+.65] ( increments for the next cut)
O101 ENDWHILE
G1 X #1 Y [#4 ] Z0
G1 X #3 Y [#4 ] Z0
G0 Z [0.5]
G0 X #1
...was suggested to me. I tweaked it for my table size, the depth of cut I wanted, the z-clearance I felt necessary, the speeds at which I comfortably cut and to make it bidirectional (surfacing with a 3/4" bit is a tedious affair when the cutter only mills one way.)
Old Tue 01 September 2009, 04:46
Jeff,
An Onsrud 91-000 1.25" Spoilboard surfacing cutter makes quick work of resurfacing the top. The price is reasonable.
Surfacing the table gixi 10. Base Table 1 Mon 10 August 2009 06:17
Gcode for surfacing table DMS CNC motion control software 2 Sun 12 October 2008 10:09
