#481
This is really embarrassing
, I can not find a copy of my mechmate material list or my bolt list. If anyone has a copy please send them to me . Thanks ![]() ![]() ![]() ![]() ![]() ![]() |
#482
JR, that's why your thread's title hasn't changed for a while - I am scared that you might not be able to find it.
#483
#484
How about you picking a title you can remember?
#485
I don't know if everyone finds the entertainment in the thread titles that I do but if it's not tooooo time consuming I would like it if you continue to name them. If it's a pain in the #%\ then say so and I'll come up with a name that will probably be a lot less entertaining.
#486
J.R. when was the last time you cut some material for boats and do you have some pic`s of those projects?
Would like to see what it looks like. |
#487
Hennie I cut out a 19' boat just before I left for Hawaii. I will take some pictures when I return home.
#488
J R
Is that a motor boat? I am thinking of building a kayak! |
#489
JR,
Did you take one of your home cut boats to Hawaii? ![]() |
#490
Nils-#12
![]() Might that be the next adventure? |
#491
Nils try this site http://www.clcboats.com/their plans are nice, A friend and I have built the 18' and the 12' from their plans alone (no kit). It was truly a lot easier than I thought possible.
Heath I know you are joking ............ cause the second checked bag was $75.00, the boat would have been $1,000,000.00 ![]() |
#492
J R,
Thanks for the site. Did you put the plans into AutoCAD so you could cut them with your machine? What have you actually built? |
#493
JR,
No I meant DRIVE it to Hawaii. ![]() |
#494
Nils it was way before I had a machine. I'll check when I get back on the exact boats we built.
#495
Made these for a local beer co, Wolf Beer. This particular brew is Timber Wolf. The cutouts will get mounted to the bar tap handles. The T is suppose to look like the wolf's head and the W is a fang. They are about .5" X 3.5" X 3.25". A few are Maple, but most are made of Ash.
#496
Nice J R
#497
Thanks Nils
#498
Nothing beats REAL WOOD... I hate mdf...looking good JR. Did they supply you with the artwork or do you do it yourself ?
#499
Nice little contract, make me feel like one of those contract making you enjoy every instance of owning a CNC ! Nicely done too
.I’m Curious JR, what size approx one is & how is it hold down and / or what was your cutting strategy / approach ? |
#500
Kobus I did one for "White Wolf" a WW with the outside of the Ws extended down to look like fangs (their design). I stayed with that idea and came up with the wolf look for the T. I used Turbocad and Sheetcam.
Robert I used 3 hand screw clamps to hold down a 1/2" X 6" X 48" board. Nested 2 parts side by side, used 5 small tabs (1/8" X 3/8") on each one to keep them in place. first I used a 1/8" upcut spiral bit to make 3 passes (50" ipm), the last one being a finish pass taking .010". I then used a 90 degree bit (same feed rate as above) to bevel the outside. The finished part is about 3 1/4" X 3 1/2" |
#501
How were you compensated? Bucks or beer?
#502
Bucks AND Beers is even better
#503
Doug they tried to sell me on a deal where I and all my friends would get free beer for the rest of our lives, but I don't even drink a 12 pack a month and I wasn't sure about you guys so I took the $50.00 instead.
#504
This is the link to the video of my MechMate cutting the TW logos.
http://www.youtube.com/watch?v=075xA1Yw7UE |
#505
J.R.
Very nice. Have you thought about cutting the V bit first? How big are the tabs you are using? Thanks |
#506
Nils the tabs are a little less than 1/8" thick and 3/8" long. The upcut spiral will leave a rough top surface. The bevel bit last removes this and you will have very little hand sanding.
#507
Let's really cool J.R.
In the video you mention a vacuum hold down. Are you using both vacuum and clamps to hold the work piece? |
#508
Wayne my spoil board is not glued down, so with high humidity it will cup a little. This is not a problem if you have a vacuum hold down system ..... it will pull it flat. Even if I'm using clamps I still use the vacuum.
#509
I have a question for anyone that has the answer. I have a drill press I am putting into service. It came with a 1725 rpm motor, I have changed it to a 3450 rpm motor. I will be using a vfd and would like to have low rpm's for tapping. Is there any differents in the capabilities of the 2 motors??? Thanks
#510
You have changed from a 4-pole motor to a 2-pole motor. The lowest speed at which you can run the motor has now doubled. The lowest speed is decided by the motor's cooling system (the fan on the back end) and the power output needed - if you want full power output, then you can only get that when the fan runs at full speed. Therefore, for long periods at reduced speeds, the power output must be reduced - still best to reduce the speeds by changing the belt pulleys.
| JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders | Gerald D | Rails & Rollers | 198 | Mon 13 April 2015 20:59 |
| Add one more CNC addict - North Carolina | rodom | Introduce yourself and start planning | 0 | Tue 01 December 2009 06:54 |
| She makes dusty MOVES! - North Carolina, USA | Jeffn11 | Construction started, but not cutting yet | 23 | Sat 01 August 2009 20:36 |
| Plasma burner started - Albemarle, North Carolina | subman | Construction started, but not cutting yet | 8 | Sat 27 September 2008 19:25 |
| One more MechMate starting - North Carolina, USA | Bernhard | Construction started, but not cutting yet | 5 | Fri 28 December 2007 16:11 |
