Thread Tools |
Swivel Head for z axis
So far I see only one post bring up the ideas for Tilt and Swivel head for Z axis. I am planing to adapt MM to use as panel saw besides router function. I don't need the tilt head to make the control easier. So all I cut will be either horizontal or vertical.
Do you have ideas where can I buy or make swivel head to mount motor/spindle? |
Rocky
If you are going to cut panels does it matter if it is horizontal and you use the router to cut them? |
The reason some of the panel is quite thick and it put much pressure on the router bit. It will be a smoother and faster cut if I use saw blade. It is just an idea at the moment. If I can find a swivel head, so far haven't find from the yahoo search.
