Old Mon 17 April 2017, 10:07
silverdog
Just call me: Sergio #70
Rome
Italy
GRBL firmware and bCNC
I am testing GRBL Arduino firmare with bCNC control software https://github.com/vlachoudis/bCNC/wiki ... Kitchen Table testing for the moment ... but I am realy impressed on haw the open source is moving ... just give a look at the Probe/Auto Level and Probe Camera Alignment ... Sonny Jeon GRBL's developer is working on a version for the ARM 32bit processors which will have much more memory and speed ....
BTW it's a 4 to 12 $ solution.
Old Wed 05 July 2017, 08:52
TheDave
Just call me: dave
Toledo (Ohio)
Sergio, thanks for the link! I was also impressed to find a CNC board for my Raspberry Pi that includes an Arduino Nano pre-programmed with Grbl software:
http://wiki.protoneer.co.nz/Raspberry_Pi_CNC
Sadly, it looks like they can only drive up to NEMA 23 motors (2.8 Amps), and I wonder if they can really do that anyway (motor drivers claim up to 2.5 Amps with additional cooling installed). But this looks to be the way of the future
Last edited by TheDave; Wed 05 July 2017 at 08:56.. Reason: how many times will I misspell "Arduino"???
Old Wed 05 July 2017, 15:06
silverdog
Rome
Italy
Dave, here a solution to connect any drivers you like to those boards :-)
https://www.banggood.com/MKS-CD-5786...mds=mywishlist
Old Thu 06 July 2017, 06:00
TheDave
Just call me: dave
Toledo (Ohio)
Sergio, that is awesome!! I see a kitchen table project for me real soon!!
Old Mon 10 July 2017, 01:29
Dumitru Ivanov
Just call me: Muresului 9
Cluj-Napoca
Romania
I'm also renovating and that table project sounds like a plan.
Old Thu 13 July 2017, 11:44
TheDave
Just call me: dave
Toledo (Ohio)
I was doing some more reading and found this on the Gecko Drive web site:
"A motor control will always draw less than 2/3 of the motor’s rated current when it is parallel (or half-winding) connected and 1/3 of the motor’s rated current when it is series (or full-winding) connected. That is to say, a 6 amp per phase motor will require a 4 amp power supply when wired in parallel and a 2 amp power supply when wired in series."
So I should be able to use NEMA 34 motors with the Protoneer board and the recommended Pololu drivers. I have no idea what the quality is on them, but it is possible. Maybe this motor?
https://www.omc-stepperonline.com/hy...s26-2006d.html
Old Fri 14 July 2017, 05:11
silverdog
Rome
Italy
uhmm ... I think pololu are a bit underpowered for a nema34 ... if you want to try that solution, use at least the drv8825 which have a maximum output of 2.5 Amp pay attention to the specification, because they generally declare the peak output but the continuos output is lower ...
this coul be a better option: http://www.watterott.com/en/SilentStepStick-TMC2130 or the tmc2100 ..... the max output is the same of drv8825.
