Old Sat 09 February 2013, 01:18
saas
Just call me: saas
ceje
Slovenia
problem assembly rails roller
..my future problems ...
I agree that the forum has all explained ...
but good advice is never excess
tx
Old Sat 09 February 2013, 21:45
Regnar
Just call me: Russell #69
Mobile, Alabama
Looks like you need to regrind your rails and this time drill the holes in the right location. All the other work arounds would take longer than regrinding and drilling.
Old Sat 09 February 2013, 22:00
SAAS
You should establish what is wrong.
1. is the table too narrow
2. or is the gantry too wide
3. or are the rails attached incorrectly.
Either way the motor swing plates will need to be in the correct place or the pinion will not engage correctly with the module 1 drive rack that is stuck to the underside of the gantry rails.
What ever fix you use, you will need to consider its impact upon the next step past just fitting the roller into the rail.
Old Sat 09 February 2013, 23:49
Picture 1: Carefully cut end off gantry, shorten tubes, reweld the end
Picture 2: Leave it like that
Gantry end assembly. Is this correct Red_boards 20. Gantry 9 Sat 05 February 2011 01:21
BOM (Build Of Materials) Grind Head Assembly M6 10 100 AA (Rail Grinding Skate) skippy Rails & Rollers 1 Sun 01 November 2009 05:11
Need opinion on round bar rails with roller Claudiu Rails & Rollers 3 Fri 03 July 2009 12:05
Re-alignment after dis-assembly - getting all parts into position at the new location kanankeban 10. Base Table 11 Sun 25 January 2009 11:48
Upper limit of weight for Gantry and Y-car assembly Sheldon Dingwall 20. Gantry 2 Wed 28 March 2007 07:34
