Step value?
It seems a common choice of motor is all-in-one with gear box having a ratio of 7.2. Also a common pinon on an output shaft is 36teeth. I went for mod 1.
Question, if most these common combinations result in steps that are not a nice round number, what step figures are you guy's using with your build? I found I had to use a fraction because rounding up to 0.015mm/s as per Mechmate excel sheet, produced to shorter cuts. giggler |
| UIM 240xx step driver help. | window_s | CNC motion control software | 13 | Mon 01 August 2011 06:17 |
| my first step , v rails | oscaryrc | Introduce yourself and start planning | 5 | Thu 12 August 2010 00:19 |
| Slight step over on second/third pass | Dan Sj0 | Troubleshooting | 2 | Sat 10 July 2010 06:55 |
| STEP 1 - Introduce myself, FFEJ from Geelong | ffej | Introduce yourself and start planning | 8 | Fri 22 January 2010 02:20 |
| Mounted X-rack's with different heights - causes step at joint. | Barman | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 10 | Tue 17 March 2009 08:03 |
