Old Mon 19 March 2007, 09:15
Manjeet Singh
My Mechmate coming up - India
Hi Gerald,
Some time back I said that I will start Building Mechmate as I got my right wrist broken in an accident it was postponed. Now I am well and started it. I had collected all the material.
My Mechmate will be of 2500mm X 1300 mm
I have cut all the raw material for the Base Table according to above size. Instead of 50mm Pipe I will be using 3" X 1.1/5" Channel. I hope within a day or two the Base Table will be completed.
I will post my day to day progress with pics.
Manjeet
Old Mon 19 March 2007, 10:44
Sorry to hear about your wrist. Good to hear that you are cutting steel!
Old Mon 19 March 2007, 20:53
Irfanulla
Manjeet,
Congrats on starting out on your Mechmate, looking forward for your Mechmate's pictures to guide many towards their build like that of Fabrica.
Hope you recover soon from your injury.
Irfan
Old Sat 24 March 2007, 12:15
Manjeet Singh
Here is Raw Material for Base Table cut and painted with Red Oxide ready for fabrication.
Old Sat 24 March 2007, 20:13
Kim Mortensen
Looking good Manjeet.....
Old Sat 24 March 2007, 22:44
Manjeet Singh
Thanks Kim, Today I will start Drilling MDF Board and start assembling.
Old Wed 04 April 2007, 22:17
Manjeet Singh
Hi All,
Here is the Assembled MDF Board. I made a drill jig to make holes in the MDF Board and Channels. This was quite easier than using MDF Board as jig to drill holes in Channels.Because Holes in the channels were drilled on Drilling Machine rather than Electric Hand Drill.
Old Wed 04 April 2007, 22:24
Manjeet,
You Posted,
"I made a drill jig to make holes in the MDF Board and Channels."
Would you mind giving details on the jig you made? I am getting close to this process and would benifit from your experience.
Thank You,
Greg
Old Thu 05 April 2007, 05:46
Manjeet Singh
Hi Greg,
It is very simple Jig made from 1.1/2" angle Iron cut exactly equal to the width of the MDF Board and then drilled with 5/16" drill according to drawing.I will post the picture of the drill jig.
Drilling channels and MDF board took only 1.1/2 hrs to comlete the job.
Manjeet
Old Thu 05 April 2007, 06:01
Manjeet, it was never intended for the mdf to be used as a drill jig. My intention was only that the MDF be screwed to the cross-bearers before (and during) welding because it holds everything in the right place and squares the whole table.
MDF = drill jig? NO
MDF = weld jig? YES
Old Thu 05 April 2007, 06:43
Thanks Manjeet and Gerald,
I have not studied those drawings in detail yet, but my "initial" impression was to use the MDF for a drill jig. That won't happen now. Only as a weld jig.
I should be cutting rails this weekend. Stay tuned. This sure is one fun project.
Old Fri 13 April 2007, 13:36
Manjeet Singh
Hi Gerald n Greg J,
May be it was a confusion but I did according to your drawings and my thaught to make it simple and easy to do it.
My next step is to weld the base table and I hope I will post my next progress tomorrow
cheers all....Manjeet
Old Sat 24 May 2014, 09:07
samagya
Just call me: Sam
Ghaziabad
Hi Manjeet,
Can you please give me BOM and wesite links to procure them?
All the best for your project.
Regards,
Samagya
Old Sat 24 May 2014, 23:49
You might want to look at the dates on this thread. Its 7 years old.
