Speed conversion table
I don't know whether other people have the same issues I do with cutting speeds in posts and on software screens. It probably has something to do with being a newbie, but I struggle when a single piece of software has both mm/s and mm/min on different screens, and then posts on websites have ipm and ft/min. Anyway, I found it necessary to build a conversion table because I could not find one ready made. Hope it's useful.
The yellow shading is the region I use for cutting EPS. |
Thanks Red, that sure helps especially when dealing with antiquated measurements based on the lengths of Royal digits and other various body parts
Personally, I like to use cutting feed speeds of around 300 furlongs per fortnight.
Brad, I dont think normal steppers will get you there, you may have to use warp drives.
| Z-Plate hole layout and metric to inch conversion variance | swatkins | 40. Z-Slide | 12 | Thu 03 November 2011 10:25 |
| Website/ Forum for homemade/conversion cnc lathe? | jgc2521 | Miscellaneous / General / Whatever / Catchall | 1 | Sun 28 February 2010 00:31 |
| CNC conversion Utility | Johannescnc | Utility software | 0 | Sun 27 December 2009 13:23 |
| Speed Test | isladelobos | General - MM Operating | 1 | Tue 13 October 2009 04:07 |
| Metric to Imperial Conversion Site | jehayes | Golden Resources | 2 | Thu 09 July 2009 20:22 |
