Gantry end assembly. Is this correct
I've studied the plans and flipped the parts and understand that cabling management depends where you bring the cables in, but I'm still unsure whether I have the correct bits bolted together, so I'd thought I'd check before squaring and welding.
I'm attempting to build a "standard" MM according to the plans. ![]() Much appreciated. Red |
The part on the left is correct, but the one on the right is not, the bent end closures must point up, so that they cover the ends of the gantry tubes.
You also need to swop the end closures on each side, on the left side the one with the slot on the side must face into the centre, on the right side you must rotate and swop ends so the tab that the cable chain connects to must point down with the triangular hole in side facing the centre. When assembled with the gantry tubes these two with the slots/holes on the sides will be on either end of the same gantry tube (which will be the rear one once on the table) Last edited by Alan_c; Sun 30 January 2011 at 23:47.. |
As for getting things upside down. Shows what happens when you get too close to the thing and plans and forget the big picture. Many thanks. |
May be I am wrong, but it looks like that the left is incorrect, The closures on the left one need to be pointing down. And the closures on the right one need to be swapped.
May be this will help visualizing http://sketchup.google.com/3dwarehou...dd05577cba1ffc The sketchup doesn't show the different type closures though. to be sure, search on the forums to get some pictures of people ![]() |
I was trying to look that up in google, but google doesn't have any pictures of the forum anymore
Google should never have had pictures of the forum because they were always "behind" the password.
you are correct and my wordings are incorrect, I used to use google to find the topics and then beable to find the pictures. This doesn't seem to work anymore. |
Is the gantry in post 1 a view of the "far" side that opposes the "near side" pics in Post 3? I think I'm getting it. I'll mock it all up with bolts and clamps and then it should sink in. Ries. Thanks I've downloaded Sketchup and will study your model. |
#10
Red These may help you !!
![]() ![]() Cheers Tony. |
| Seating the Y Gantry on the X Rails - correcting a twisted gantry | Greg J | 20. Gantry | 30 | Wed 14 April 2010 03:55 |
| BOM (Build Of Materials) Grind Head Assembly M6 10 100 AA (Rail Grinding Skate) | skippy | Rails & Rollers | 1 | Sun 01 November 2009 06:11 |
| Re-alignment after dis-assembly - getting all parts into position at the new location | kanankeban | 10. Base Table | 11 | Sun 25 January 2009 12:48 |
| Upper limit of weight for Gantry and Y-car assembly | Sheldon Dingwall | 20. Gantry | 2 | Wed 28 March 2007 08:34 |
