Old Wed 07 July 2010, 00:13
Zouave
Just call me: Eric #115
Sacramento, CA
Dust Collection Through Stiffener Tube?
I was curious if anyone has worked with using the stiffening tube for the purpose of routing dust through it, instead of what seems to be the traditional option of using the back side of the spider.
Comments/suggestions?
Old Wed 07 July 2010, 03:07
You want the dust tube to be at least 4" in diameter. If you plan to make the stiffening tube as you call it 4", then that will work fine.
Old Wed 07 July 2010, 08:04
Are you talking about the 1" x 2" vertical back bone to the 4" ground steel vee grooved plate?
Sounds problematic. (small cross section, not smooth)
Old Wed 07 July 2010, 10:20
Zouave
Sacramento, CA
It was more something I was curious about. Having a 4" hose leading to it would give it rather significant airspeed, which I think is probably more important than air volume, given the application. I am going to experiment with some different setups and see what happens.
Dust Collection Pipes sailfl 55. Dust Management 15 Mon 22 February 2010 05:23
Dust Collection Ground Wire sailfl 55. Dust Management 1 Sat 02 May 2009 07:36
Where to start in dust collection WTI 55. Dust Management 0 Sat 29 November 2008 20:28
Dust collection piping design & supply Gerald D 55. Dust Management 2 Fri 03 October 2008 10:53
Interesting Dust Collection Software Brian_B Golden Resources 4 Sun 25 May 2008 20:32
