Old Tue 11 May 2010, 03:43
cnc'tje
Just call me: newbie
Brussels
Belgium
What voltage power suply?
Hi all,
i've been reading these forums very carefully these past weeks, and it looks like i'm allmost ready to order the parts for my own cnc machine.
So far i decided to make use of the Motion King motors (34HS9801) with a 3 to 1 belt reduction, and gecko 203V drivers.
The output voltage of the power supply, is still my concern.
What output voltage do i need, and will 500VA be enough?
Im pretty sure that some of you MM users have got the same configuration, maybe you guys can tell me wich Voltage works best?
I can't wait to start building. . .
Old Tue 11 May 2010, 05:53
I have the exact same config as you and I bought this transformer:
400VA transformer Objectnr. AN-4442
500VA is plenty, I bought 400VA because I wanted to add a 4th stepper...
Ries
Old Tue 11 May 2010, 08:18
cnc'tje
Brussels
Belgium
Thx Ries, looks great,
but wich output voltage did you use, 42V? Or did you combine some outputs to create a different output value?
Old Tue 11 May 2010, 08:29
The Motion King 34HS9801 motor is rated 4.1mH, so, if you wire it half-coil, you could use a power supply of up to 65VDC. 42VDC should be perfectly adequate, although I would probably select a 50VDC power supply as a good compromise between excessive heat and maximum speed. A transformer with a 35VAC winding would give you about 50VDC.
Old Tue 11 May 2010, 08:34
I did wire the two 42Volt outputs in parallel to get the desired end voltages that is around 59.5VAC, minus 1.4V of the rectifier bridge you get around 58Volt I believe.
This falls around 7 Volts below the calculated maximum voltage for these steppers according to Maris his formulas. sqrt(4.1)*32=64.8V
In terms of heat generation within my box it falls well within the limits of all components, although I had to create one additional ventilator to pass cool air through the control box from outside through a filter. This properly also has something to do with that my laptop is also mounted in my control box.
Ries
One additional note in response to mike.
My stepper motors will get warm, measured with a simple heat thermometer I get around 45 degrees on the outside of the stepper.
My Gecko's will get a but warmer, but never measured. However I can always touch the cooling plate without problems (for minutes at a time with hand).
Last edited by riesvantwisk; Tue 11 May 2010 at 08:39.. Reason: response to mike..
Old Tue 11 May 2010, 08:54
cnc'tje
Brussels
Belgium
Thanks for the reply Mike, but i guess im gonna go with the PSU that Ries uses in his MechMate. This way I'm at least sure that everything will work propper, without over heating.
Calculate the Voltage and VA size of the DC power supply for stepper motors/geckos Gerald_D 702. Power Supplies 134 Fri 13 November 2015 09:09
Wiring the PK296A2A-SG7.2 motors & power supply voltage selection Richards Motors & their mountings 97 Fri 29 July 2011 10:46
Max power supply voltage for Gecko G540 shaper 701. Motor Drives 6 Tue 11 August 2009 10:38
Why Mariss uses 32 X SQRT(Inductance) to calculate voltage of power supply Richards 702. Power Supplies 5 Wed 08 April 2009 20:50
My power supply voltage is too high - what can I do? revved_up 702. Power Supplies 11 Sun 20 April 2008 19:35
