Old Thu 09 September 2010, 13:31
renraku
Just call me: renraku
rome
Italy
how to assign gecko driver to motors?
how to assign driver to motors? for example, what is of the gecko driver for axis's Z ? Thanks
Old Thu 09 September 2010, 15:00
The gecko drives are assigned in Mach 3 under the Ports and Pins menu
The PMDX manual has the mapping for your J1 thru J4 ports and pins.
Is that what you are asking?
Mine is set up this way (this procedure borrowed from Mike Richards originally) :
Here's the way that I have Mach 3 configured for my G203 stepper drivers:
X-axis enabled (GREEN Check Mark), Step = pin 3, Direction = pin 2, Step Active Low = RED X, Dir Active Low = RED X
Y-axis enabled (GREEN Check Mark), Step = pin 5, Direction = pin 4, Step Active Low = RED X, Dir Active Low = RED X
Z-axis enabled (GREEN Check Mark), Step = pin 7, Direction = pin 6, Step Active Low = RED X, Dir Active Low = RED X
A-axis enabled (GREEN Check Mark), Step = pin 9, Direction = pin 8, Step Active Low = RED X, Dir Active Low = RED X
Slave Axis: A is slaved to X
On the PMDX-122:
JP1 is set with the jumper on the bottom (between GND and the center pin)
JP2, JP4, JP5 are all jumpered with the jumper on the top two pins (closest to the cable connector)
JP3 is jumpered with the jumper on the top two pins (away from the green connector)
A 12V power supply is plugged into J11
NOTE: The L.E.D.s for pins 2, 4, 6, 8 will be ON when the steppers are turning one directions and OFF when the steppers are turning the other direction. The L.E.D.s for pins 3,5,7,9 may be ON or OFF depending on the status of the step pulse, but those L.E.D.s should flicker ON/OFF when the motors are turning.
With a multi-meter, check your wiring between the problem G203's Step, Direction, and Common pins and the PMDX-122's Step, Direction, and Common pins to verify that resistance readings between connection pins shows zero resistance (with the power off!).
Old Fri 10 September 2010, 04:26
renraku
rome
Italy
Yes is it, thanks so much.
Old Sun 12 September 2010, 16:48
Red_boards
Just call me: Red #91
Renraku,
I downloaded a configuration file from PMDX for the PMDX-125/Geckos. Just save it and point Mach3 to it and most settings come out right (but you have to manually slave the 4th motor (A axis) to the x-axis as Sean described).
Red
digital stepping driver KenC 701. Motor Drives 7 Sun 20 June 2010 11:20
Inexpensive 3-axis driver boards Supertechster 701. Motor Drives 15 Wed 10 March 2010 10:04
Would you mind to help me to solve the problem for Keling stepper Motor Driver? qangel1000 Motors & their mountings 6 Sat 08 August 2009 00:42
Found a new type of driver could save some money please help? shelbygt500buddy 701. Motor Drives 8 Tue 09 June 2009 18:48
Keling Stepper, Servo Motor and Driver Kelinginc The Market Place 0 Wed 16 January 2008 14:55
