Old Sat 01 November 2008, 08:43
Sean I need help. I need to cut some .25 lexan, any suggestions on parameters, or suggest a clear plastic that will cut better. I will be doing some lettering and also some graphics. thanks
Old Sat 01 November 2008, 17:46
JR,
Lexan is also known as Polycarbonate for those that don't know.
I recommend a onsrud #52-624 or similar 1/4" diameter.
Cut at 15K RPM or so, 35-60ipm, 2 - 1/8" per pass.
Old Sat 01 November 2008, 19:37
Thanks for the info Sean, I'll give it a try.
Old Sat 01 November 2008, 20:03
...JR, a little additional information.
Get a spiral up bit, 1 or 2 flute made for soft plastic.
The real key is get the chips out of the cutting path, otherwise they weld themselves back in the kerf and make for an ugly part.
Acrylic is really known for this, Polycarbonate doesn't weld as much, but it's really soft compared to other cutting materials.
Old Sat 01 November 2008, 23:17
cncb
Just call me: Brian
Connecticut
I would recommend cutting most plastics with an o-flute cutter. I cut this with a 1/4" o flute up spiral and as Sean says good to get rid of the chips; up spirals do just that. Leaves a really smooth finish quite minimal chatter/tool marks if any. Not lexan, but cast acrylic. I'm sure it would cut very similar.
Old Sat 01 November 2008, 23:19
cncb
Just call me: Brian
Connecticut
http://www.woodcraft.com/family.aspx?familyid=8017 here's the one I use, but onsrud and amana, most companies carry them
Old Sun 02 November 2008, 05:32
Thanks for the help guys Brian that's a nice cut.
Old Sun 02 November 2008, 20:15
Brian.
That is the same quality of cut I getting on my machine as well with Spiral Up Onsrud bits.
Thanks for posting a picture!
Old Sun 02 November 2008, 23:26
cncb
Just call me: Brian
Connecticut
Np; but I def noticed a huge improvement in quality of cut in plastics when I went to the O-Flute. It just ejects chips nicer and leaves a cleaner finish. Onsrud, whatever company you use o-flute for plastics seems to be the way to go.
